radio display fault
Petecog79
296
59 plate fr . My radio display sometimes doesn't come on once I turn ignition though radio works fine. It will eventually come on by turning ignition on and off. It happens mainly when been stood . Any ideas what it could be it's only the basic radio no sat nav just red display.
Hamburgalarr
104
Checked your car battery voltage? Also wiring in back of radio (you'll need a set of radio openers from halfords) also check relevant fuses. Possibly cracked fuse?
RayJ
Groucho
Mar 5, 2016
Haywards Heath
Common Fault?
Hi,
Those symptoms are identical to the ones I have on my Mk2 Jan 2010 '59'. The key appears to be 'left standing'. I picked the car up from the dealers on Tues and when I started it Fri morning : dead display, good audio. It was fine later on that day though.
Am monitoring because intermittent faults can be a right b****rd to find - and if the On/Off routine works : I can live with that :D
