Secondary air injection problems
does u av da b00st or not?
  • occasionally i have to wait for boost
    Votes: 11 47.8%
  • every time i start the car i have to wait for boost
    Votes: 2 8.7%
  • boost from the word go, never have to wait ever
    Votes: 10 43.5%
  • Total voters
    23
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
just had a thought while trying to help Big_Lad
the n112 valve controls boost in some way...as its connected to the actuator/n75 etc by vac hoses, is this while the secondary air pump is activated?
theres been lots of talk in the past about how some people have no boost at all while the car warms up and then after a few mins its available.
a while back id be waiting up to 20mins before i had any boost but i was told this was normal (obviously wasnt!!)
anyway i swapped all the vac hoses and from then on the most i was/have been waiting is around 3mins max sometimes its like 30 seconds. other times there's boost from the moment you turn the key...odd
for the poll state whether you have to wait occasionally or not
T7ODD
When the car is cold and the secondary pump is activated, as soon as the pump stops (approx 30 secs) I have boost.
If the car is still warm and the secondary pump doesn't need to engage when you re-start, there is boost available immediately.
Jul 10, 2001
972
Bedfordshire
Cheers for this acid.
I've submitted my "vote" I do occasionaly have to wait for boost, but it isn't anymore than a few minutes at the very most.
But there have been occasions where i've not had to wait at all. :confused:
acidstrato
Dec 9, 2004
5,942
like i said in the first post, before...i was sometimes waiting up to 20mins for any boost to appear! id be almost at the end of my journey when all of a sudden it was there and available! how weird is that?
but ever since i swapped the vac hoses i never have to wait more than a couple mins, usually 3 minutes max. but the strange thing is it doesnt happen everytime the car is cold e.g. every first start of the day. some days i can just go and its there. almost as if its influenced by ambient temps or something :confused:
Beaker™
Slightly Unhinged........
Nov 21, 2005
1,900
C:\UK\Glos
Usually i can boost straight away, unless its real cold (ie 5.30am in winter) then i have to wait around 30secs - 1min.
acidstrato
Dec 9, 2004
5,942
yeah the note is substantially different when its kicked in its just abit random to whether it happens or not.
i did think of doing away with it but as it has no real benefit id rather not, plus i cant really be arsed to get my hands dirty removing the pump
roly
midnightmotors.net
Jan 2, 2002
1,879
Midnight Motors Workshop
i used to have to wait approx 30 secs for any boost but then would be fine untill the next cold start, ie following morning
i removed all the secondary air pump gubbins at the weekend but haven't driven the car from cold since so can't comment on it yet, will let you know my findings when i do though
h17och
the hunt is over. 460bhp
Sep 1, 2005
3,504
Dunstabubble
there is a gain from it...faster oil filter removal... pisses me off!
roly...no codes then? how is you motor?
HoocH
acidstrato
Dec 9, 2004
5,942
if you do a decent job of removing it you have it kicking in straight away holding you back and, you wont get any common fault codes
but that's about it, i suspect you'll get more fault odes than normal if you dunno what your doing tho
May 2, 2006
2,758
i voted boosted from the word go, coz if i wanted to i could, but i dont, i normally give it a good 10mins or wait for water and oil to heat up fully before i boot it,
h170ch/phil/roly :- either of you going to be doing any guides for removing this, or is it just a case of following it back to the pump, removing it and blanking? although mine seems to be working fine, im a fan of ditching stuff i dont need
Craig!
IHI Ibiza Cupra
Jan 6, 2005
1,876
Guisborough
www.vagcars.co.uk
Where the blanking plate is fitted to, at the other side of this valve there is a vaccuum line. I don't know whether to leave this in place, or remove it and block off that too.
It all depends on what the vaccuum line is for, whether its to open a valve or was just there for fun.
