Software (firmware)
Mikeyfraser
151
Hello hope you all had a good new year.
Quick question I had my 09 plate leon in at a auto tech about my Bluetooth and got told need complete software update for it to work.
I have 5P0035680A headunit. RNS 510 version A. What's the most up to date software and where can I get it from?
Thanks in advance.
Mikey
rllmuk
1,241
The RNS510 you have, and bluetooth module under seat, were a factory fit. Bluetooth is not built in to the headunit. What do you mean for it to work? What are you asking?
Mikeyfraser
151
The bluetooth does not work. Have been told I need a full software update on the headunit to allow the Bluetooth to work. So I'm asking what is the latest software and where can I get it cheap?
rllmuk
1,241
Bluetooth has nothing to do with the headunit. I've had the OEM stereo unit, RCD510 & RNS510 in mine, and all have zero effect on it. It's a separate module, that lives under the drivers seat. Your Leon (assume it's facelift?) may have come with the RNS310/315 which DID have the bluetooth built in, which if you no longer have it would explain why it doesn't work.
Either way, we need more info to assist.
Mikeyfraser
151
I have been to a local vw specialist and that's what they where saying. I need s software update and was going to take 4hrs to download so it would work with my iPhone 5s. They advices against this as it was going to run into hundreds of pounds. They have access to the full vw database where they got the info and most of it was in spainish.
rllmuk
1,241
Odd, maybe they mean an update for the bluetooth unit? Well I'd have a look on vwnavi.com or briskoda as there's a guy on there that knows an awful lot about the under seat bluetooth modules. However, both our 2008 plated cars work fine with iphone 5/5s with it as it came out of the factory. One even has the Seat RNS510 you have.
Mikeyfraser
151
Okay I'm on vwnavi. Do you know who the person is so I could search for him on it? It's strange how it's not working. It's never worked since I bought the car in July 2013.
rllmuk
1,241
No, don't know the name. But, I'd ask in here. If you can get the part number of your under seat unit to add to the description it'll help. Also have you had the car scanned with VCDS for faults?
Mikeyfraser
151
The Bluetooth part number is 5P0862335B. Okay. Hopefully someone might post in this thread. Yes I have done an auto scan a wee while back.
Mikeyfraser
151
Code:
Chassis type: 1P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72 77
01 - engine - status: OK 0000
03 - ABS brakes - status: OK 0000
04 - steering angle - status: OK 0000
08 - HVAC - status: OK 0000
09 - cent. Elect - status: malfunction 0010
15 - airbags - status: OK 0000
16 - steering wheel - status: OK 0000
17 - instruments - status: OK 0000
19 - CAN gateway - status: malfunction 0010
25 - immobiliser - status: OK 0000
37 - navigation - status: malfunction 1010
42 - door elect, driver - status: OK 0000
44 - steering assist - status: OK 0000
46 - central conv - status: malfunction 0010
52 - door elect, pass - status: OK 0000
56 - radio - status: malfunction 1010
62 - door, rear left - status: OK 0000
72 - door, rear right - status: OK 0000
77 - telephone - status: cannot be reached 1100
address 01: engine           Labels: 03G-906-016-BKC.lbl
part no SW: 03G 906 021 SC.      HW: 03G 906 021 AN
component: R4 1.9L EDCS G000SG 1438
revision: --H08-- serial number SEX7Z0H83130H6
coding: 0050071
shop#. WSC 66565 257 00032
VCID: 72E1CE786D7B258E927-8027
no faults found
readiness: 0 0 0 0 0
Address 03: ABS brakes (-----).        Labels: 1K0-907-379-60B
part no SW: 1K0 907 379 AD      HW: 1K0 907 379 AD
Component: ESP MK60EC1    H35 0104
revision: 00H35001
coding: 133B201209240002C80B04E8902000813400
shop#. WSC 04941 000 00000
VCID: 74EDC860D76F2BBE80B-8021
no fault code found.
address 09: cent. Elect.      Labels: 3C0-937-049-30.H.lbl
part no SW: 3C8 937 049 E.     HW: 3C8 937 049 E
component: bordnetz-SG       H54 2602
revision: 00H54000   Serial number: 00000005864137
coding: 81880F2F00041000431D00000000000000007F075C40000C0
shop#. WSC 06402 785 00200
VCID: 336F0B7C52E16C86591-8066
subsystem 1- part no:1P0 955 119 B     Labels: 1KX-955-119.CLB
component: wischer 300608 002 0601
coding: 00056208
shop#. WSC 06402
1 fault found
01504 - bulb for license-plate light (X)
012 - electrical fault in circuit - intermittent
freeze frame:
fault status: 00101100
fault priority: 2
fault frequency: 5
reset counter: 150
mileage: 51511km
time indication: 0
freeze frame:
ON
voltage: 11.85V
ON
ON
OFF
OFF
OFF
Address 15: airbags.     Labels: 5N0-959-655.lbl
part no SW: 5N0 959 655 A.    HW: 5N0 959 655 A
component: J234_A03 VW10 HI  1815
revision: 19013000.   Serial number: 0039DPDP46T+
coding: 0012339
VCID: 3B7F235C7AB1A4C6811-806E
subsystem 1 - serial number: 6333FTS665711788
subsystem 2 - serial number: 6343FTS610751788
Subsystem 3 - serial number: 6353ETS6DFBQUVNH
subsystem 4 - serial number: 6363ETS6TUPLUVNP
subsystem 5 - serial number: 00000000000000000
subsystem 6 - serial number: 00000000000000000
address 16: steering wheel.      Labels: 1K0-953-549-MY8.lbl
part no SW: 1K0 953 549 BS    HW: 1K0 953 549 BS
component: J0527   7520101
coding: 0002042
VCID: 840D18A0C7CF9B3E30B-80D1
subsystem 1 - part no: XXXXXXXXXXX
Component: E0221    002 0010
no fault cod found.
address 17: instruments.     Labels: 1K0-920-xxx-17.lbl
part no: 1P0 920 947 B
component: KOMBIINSTRUMENT V03 0750
coding: 0002401
shop#. WSC 18069 210 95564
VCID: 32610E78ADFB658E527-8067
no fault code found
address 19: CAN Gateway.     Labels: 1K0-907-530-V3.clb
part no SW: 1K0 907 530 Q.  HW: 1K0 907 951
component: J533_Gareway    H16 0202
revision: H16    Serial number: 2700K087100971
coding: E9807F064006020203
VCID: 356B35645C9572B6775-8060
3 faults found
01303 - Telephone transceiver (R36)
004- no signal/communication
Freeze frame :
Fault status: 01100100
Fault priority: 2
Fault frequency: 1
Reset counter: 142
mileage: 28528km
time indication: 0
date: 2000.00.00
time: 21:16:46
01300 - control module for navigation with CDROM (J401)
004 - no signal/communication - intermittent
Freeze frame:
Fault status: 00100100
Fault priority: 2
Fault frequency: 254
Reset counter: 151
mileage: 28528km
time indication: 0
date: 2000.00.00
time: 21:20:00
01304 - radio
Freeze frame:
Fault priority: 2
Reset counter: 151
mileage: 28528km
time indication: 0
date: 2000.00.00
time: 21:20:00
address 25: immobilizer.      Labels: 1T0-035-680.clb
component: IMMO      V03 0750
shop#. WSC 00000 000 00000
no fault codes found.
address 37: navigation (J0506)     Labels: 1T0-035-680.clb
Part no SW: 5P0 035 680 A       HW: 5P0 035 680 A
component: RNS-MID     H05 1036
revision: AB001001     Serial number: SEZ6Z7L9137058
coding: 0C000440040200030020
shop#. WSC 00829 210 91891
VCID: 2C5D10004FDF337E18B-8079
4 faults found
00880 - connection to speaker rear left
freeze frame:
fault priority: 5
fault frequency: 1
reset counter: 126
mileage: 51160km
time indication: 0
00856 - radio antenna
011 - open circuit - intermittent
freeze frame:
fault status: 00101011
fault priority: 5
fault frequency: 2
reset counter: 149
mileage: 51568km
time indication: 0
Freeze frame :
Fault status: 01100000
Fault priority: 5
Fault frequency: 1
Reset counter: 142
mileage: 28528km
time indication: 0
date: 2000.00.00
time: 21:16:46
00862 - antenna for GPS navigation (R50/R52)
011 - open circuit
Freeze frame:
Fault priority: 5
Fault frequency: 18
Reset counter: 112
mileage: 30189km
time indication: 0
date: 2000.00.00
time: 17:32:14
Address 42: door elect, driver      Labels: 1K0-959-701-MAX3.lbl
part no SW: 1T0 959 701 L          HW: 1K0 959 793 P
component: J386   TUER-SG FT    1518
revision: 71009005      Serial number: 00000295288510
coding: 0004784
shop#. WSC 00829 210 97507
VCID: 408554B01357C71ED43-8015
address 44: steering assist         Labels: 1Kx-909-14x-44.clb
part no: 1K0 909 144 C
component: EPS_ZFLS KL. 77     2301
revision: 00H15000
VCID: 2A511618852B2D2D4EE7-807F
address 46: Central conv.       Labels: 1K0-959-433-MAX.clb
Part no SW: 1K0 959 433 BT     HW: 1K0 959 433 BT
component: KSG PQ35 G2   020 0204
revision: 00020000     Serial number: 00000000000000
coding: 198000405283CC7F7F00850560085F86F07C00
shop#. WSC 00829 210 90032
VCID: 830F1BBCC2C19C06091-80D6
subsystem 5 - part no: 1P0 951 171
component: innenraumueberw.010 4971
coding: 00000000
shop#. WSC 00829
subsystem 6 - part no: 1K0 951 605 C
component: LIN BACKUP HORN H03 1301
subsystem 7 - component        NGS n.mounted
1 fault found
01135 - interior monitoring sensors
freeze frame:
fault status: 00100100
fault priority: 4
fUlt frequency: 2
reset counter: 151
time indication: 0
address 52: door elect, pass      Labels: 1K0-959-702-MAX3.lbl
part no SW: 1T0 959 702 L        HW: 1K0 959 792 P
component: J387   TUER-SG BT    1518
revision: 71009005      Serial number: 00000278388505
coding: 0004784
VCID: 418351B4185DCE16DBD-8014
no fault code found
address 56: radio (J0506)      Labels: 1T0-035-680.clb
4 faults found
freeze frame:
fault priority: 5
fault frequency: 1
reset counter: 126
mileage: 51160km
time indication: 0
Freeze frame:
fault priority: 5
fault frequency: 2
reset counter: 149
mileage: 51568km
time indication: 0
Freeze frame :
Fault priority: 5
Fault frequency: 1
Reset counter: 142
mileage: 28528km
time indication: 0
date: 2000.00.00
time: 21:16:46
011 - open circuit
Freeze frame:
Fault priority: 5
Fault frequency: 18
Reset counter: 112
mileage: 30189
time indication: 0
date: 2000.00.00
time: 17:32:14
address 62: door, rear left         Labels: 1K0-959-703-GEN3.lbl
pert no SW: 1K0 959 703 AF      HW: 1K0 959 795 S
component: J388  TUER-SG HL    1401
revision: 11006001     Serial number: 00000003318110
coding: 0000144
VCID: 74EDC860176F2BBE80B-8021
Address 72: door, rear right       Labels: 1K0-959-704-GEN3.lbl
part no SW: 1K0 959 704 AF      HW: 1K0 959 794 S
component: J389   TUER-SG  HR    1401
revision: 11006001     Serial number: 00000003328954
coding: 0000144
VCID: 75EBF5641C1532B6B75-8020
no fault code found
Address 77: Telephone
cannot be reached
rllmuk
1,241
Well at least VCDS is telling you it's not working too. Seems more fundamental than a software update to me, no commuication at all, but will leave to those with more knowledge than I.
Mikeyfraser
151
Yeah and I no I'm getting voltage to it but just not working. So might be the module itself. Where does it display on yours that your connected to bluetooth and search for it?
Is it on the display on the left hand side of your speedo etc and you use the buttons on the right stalk.
