Chassis type: 1P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72 77
01 - engine - status: OK 0000
03 - ABS brakes - status: OK 0000
04 - steering angle - status: OK 0000
08 - HVAC - status: OK 0000
09 - cent. Elect - status: malfunction 0010
15 - airbags - status: OK 0000
16 - steering wheel - status: OK 0000
17 - instruments - status: OK 0000
19 - CAN gateway - status: malfunction 0010
25 - immobiliser - status: OK 0000
37 - navigation - status: malfunction 1010
42 - door elect, driver - status: OK 0000
44 - steering assist - status: OK 0000
46 - central conv - status: malfunction 0010
52 - door elect, pass - status: OK 0000
56 - radio - status: malfunction 1010
62 - door, rear left - status: OK 0000
72 - door, rear right - status: OK 0000
77 - telephone - status: cannot be reached 1100
address 01: engine Labels: 03G-906-016-BKC.lbl
part no SW: 03G 906 021 SC. HW: 03G 906 021 AN
component: R4 1.9L EDCS G000SG 1438
revision: --H08-- serial number SEX7Z0H83130H6
coding: 0050071
shop#. WSC 66565 257 00032
VCID: 72E1CE786D7B258E927-8027
no faults found
readiness: 0 0 0 0 0
Address 03: ABS brakes (-----). Labels: 1K0-907-379-60B
part no SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0104
revision: 00H35001
coding: 133B201209240002C80B04E8902000813400
shop#. WSC 04941 000 00000
VCID: 74EDC860D76F2BBE80B-8021
no fault code found.
address 09: cent. Elect. Labels: 3C0-937-049-30.H.lbl
part no SW: 3C8 937 049 E. HW: 3C8 937 049 E
component: bordnetz-SG H54 2602
revision: 00H54000 Serial number: 00000005864137
coding: 81880F2F00041000431D00000000000000007F075C40000C0
shop#. WSC 06402 785 00200
VCID: 336F0B7C52E16C86591-8066
subsystem 1- part no:1P0 955 119 B Labels: 1KX-955-119.CLB
component: wischer 300608 002 0601
coding: 00056208
shop#. WSC 06402
1 fault found
01504 - bulb for license-plate light (X)
012 - electrical fault in circuit - intermittent
freeze frame:
fault status: 00101100
fault priority: 2
fault frequency: 5
reset counter: 150
mileage: 51511km
time indication: 0
freeze frame:
ON
voltage: 11.85V
ON
ON
OFF
OFF
OFF
Address 15: airbags. Labels: 5N0-959-655.lbl
part no SW: 5N0 959 655 A. HW: 5N0 959 655 A
component: J234_A03 VW10 HI 1815
revision: 19013000. Serial number: 0039DPDP46T+
coding: 0012339
VCID: 3B7F235C7AB1A4C6811-806E
subsystem 1 - serial number: 6333FTS665711788
subsystem 2 - serial number: 6343FTS610751788
Subsystem 3 - serial number: 6353ETS6DFBQUVNH
subsystem 4 - serial number: 6363ETS6TUPLUVNP
subsystem 5 - serial number: 00000000000000000
subsystem 6 - serial number: 00000000000000000
address 16: steering wheel. Labels: 1K0-953-549-MY8.lbl
part no SW: 1K0 953 549 BS HW: 1K0 953 549 BS
component: J0527 7520101
coding: 0002042
VCID: 840D18A0C7CF9B3E30B-80D1
subsystem 1 - part no: XXXXXXXXXXX
Component: E0221 002 0010
no fault cod found.
address 17: instruments. Labels: 1K0-920-xxx-17.lbl
part no: 1P0 920 947 B
component: KOMBIINSTRUMENT V03 0750
coding: 0002401
shop#. WSC 18069 210 95564
VCID: 32610E78ADFB658E527-8067
no fault code found
address 19: CAN Gateway. Labels: 1K0-907-530-V3.clb
part no SW: 1K0 907 530 Q. HW: 1K0 907 951
component: J533_Gareway H16 0202
revision: H16 Serial number: 2700K087100971
coding: E9807F064006020203
VCID: 356B35645C9572B6775-8060
3 faults found
01303 - Telephone transceiver (R36)
004- no signal/communication
Freeze frame :
Fault status: 01100100
Fault priority: 2
Fault frequency: 1
Reset counter: 142
mileage: 28528km
time indication: 0
date: 2000.00.00
time: 21:16:46
01300 - control module for navigation with CDROM (J401)
004 - no signal/communication - intermittent
Freeze frame:
Fault status: 00100100
Fault priority: 2
Fault frequency: 254
Reset counter: 151
mileage: 28528km
time indication: 0
date: 2000.00.00
time: 21:20:00
01304 - radio
Freeze frame:
Fault priority: 2
Reset counter: 151
mileage: 28528km
time indication: 0
date: 2000.00.00
time: 21:20:00
address 25: immobilizer. Labels: 1T0-035-680.clb
component: IMMO V03 0750
shop#. WSC 00000 000 00000
no fault codes found.
address 37: navigation (J0506) Labels: 1T0-035-680.clb
Part no SW: 5P0 035 680 A HW: 5P0 035 680 A
component: RNS-MID H05 1036
revision: AB001001 Serial number: SEZ6Z7L9137058
coding: 0C000440040200030020
shop#. WSC 00829 210 91891
VCID: 2C5D10004FDF337E18B-8079
4 faults found
00880 - connection to speaker rear left
freeze frame:
fault priority: 5
fault frequency: 1
reset counter: 126
mileage: 51160km
time indication: 0
00856 - radio antenna
011 - open circuit - intermittent
freeze frame:
fault status: 00101011
fault priority: 5
fault frequency: 2
reset counter: 149
mileage: 51568km
time indication: 0
Freeze frame :
Fault status: 01100000
Fault priority: 5
Fault frequency: 1
Reset counter: 142
mileage: 28528km
time indication: 0
date: 2000.00.00
time: 21:16:46
00862 - antenna for GPS navigation (R50/R52)
011 - open circuit
Freeze frame:
Fault priority: 5
Fault frequency: 18
Reset counter: 112
mileage: 30189km
time indication: 0
date: 2000.00.00
time: 17:32:14
Address 42: door elect, driver Labels: 1K0-959-701-MAX3.lbl
part no SW: 1T0 959 701 L HW: 1K0 959 793 P
component: J386 TUER-SG FT 1518
revision: 71009005 Serial number: 00000295288510
coding: 0004784
shop#. WSC 00829 210 97507
VCID: 408554B01357C71ED43-8015
address 44: steering assist Labels: 1Kx-909-14x-44.clb
part no: 1K0 909 144 C
component: EPS_ZFLS KL. 77 2301
revision: 00H15000
VCID: 2A511618852B2D2D4EE7-807F
address 46: Central conv. Labels: 1K0-959-433-MAX.clb
Part no SW: 1K0 959 433 BT HW: 1K0 959 433 BT
component: KSG PQ35 G2 020 0204
revision: 00020000 Serial number: 00000000000000
coding: 198000405283CC7F7F00850560085F86F07C00
shop#. WSC 00829 210 90032
VCID: 830F1BBCC2C19C06091-80D6
subsystem 5 - part no: 1P0 951 171
component: innenraumueberw.010 4971
coding: 00000000
shop#. WSC 00829
subsystem 6 - part no: 1K0 951 605 C
component: LIN BACKUP HORN H03 1301
subsystem 7 - component NGS n.mounted
1 fault found
01135 - interior monitoring sensors
freeze frame:
fault status: 00100100
fault priority: 4
fUlt frequency: 2
reset counter: 151
time indication: 0
address 52: door elect, pass Labels: 1K0-959-702-MAX3.lbl
part no SW: 1T0 959 702 L HW: 1K0 959 792 P
component: J387 TUER-SG BT 1518
revision: 71009005 Serial number: 00000278388505
coding: 0004784
VCID: 418351B4185DCE16DBD-8014
no fault code found
address 56: radio (J0506) Labels: 1T0-035-680.clb
4 faults found
freeze frame:
fault priority: 5
fault frequency: 1
reset counter: 126
mileage: 51160km
time indication: 0
Freeze frame:
fault priority: 5
fault frequency: 2
reset counter: 149
mileage: 51568km
time indication: 0
Freeze frame :
Fault priority: 5
Fault frequency: 1
Reset counter: 142
mileage: 28528km
time indication: 0
date: 2000.00.00
time: 21:16:46
011 - open circuit
Freeze frame:
Fault priority: 5
Fault frequency: 18
Reset counter: 112
mileage: 30189
time indication: 0
date: 2000.00.00
time: 17:32:14
address 62: door, rear left Labels: 1K0-959-703-GEN3.lbl
pert no SW: 1K0 959 703 AF HW: 1K0 959 795 S
component: J388 TUER-SG HL 1401
revision: 11006001 Serial number: 00000003318110
coding: 0000144
VCID: 74EDC860176F2BBE80B-8021
Address 72: door, rear right Labels: 1K0-959-704-GEN3.lbl
part no SW: 1K0 959 704 AF HW: 1K0 959 794 S
component: J389 TUER-SG HR 1401
revision: 11006001 Serial number: 00000003328954
coding: 0000144
VCID: 75EBF5641C1532B6B75-8020
no fault code found
Address 77: Telephone
cannot be reached
