The Leon is home guys, new cam fitted
Degsy
212
Merseyside
Well got the Leon home this evening and shes all done drives like it did before cam failed.
New Cam Kit, cam , buckets, shells.
New cam belt and water pump
x4 glow plugs
oil and filters
so made up to have her back, shes like an old pair of slippers you what i mean when you just feel comfortable and relaxed in something :D
so decided I am going to sort boost pipes out as the the two in and out of the fmic the lugs are worn and definitely feel im loosing pressure here.
so going to order some new seals and clips for all the others:
I have the following numbers which i think are right but appreciate if anyone can confirm.
turbo pressure hose's
1J0145834AE
1J0145762BF
1J0145828R
1J0145834AA
1J0145838AG
dont think I need all of these, need the two in and out of fmic, top one is ok,need the red one from turbo down i think or might get away with new seals and clips. Plastic one across the front is ok. will look better tomorrow but think im along the right lines.
8 orings needed
6 x 3C0145117F
2 x 3C0145117
if anyone has done a pipe upgrade and have any decent original hoses left lying around for pd150 ARL then drop me a message to discuss sale prices
cheers guys
D.
Gaz7
385
The standard kit can be refreshed quite nicely by replacing the clips and seals, and using a needle file to reshape the lugs on the pipes.
Degsy
212
Merseyside
cheers gaz good to know might go with two bottom ones in an out of fmic as they are the most worn and refresh seals and clips on the others then to start with.
D.
Gaz7
385
Although , it does depend on how badly the lugs are worn ! Have you looked at prices of standard boost hoses yet? Extortionate! Would be cheaper to front mount than replace them all!
Degsy
212
Merseyside
yeah been looking tonight robbing gits for some hoses.
car is high mileage and no plans for any performance upgrades so standard IC should be good enough its the crappy OEM pipes that let it down.
can anyone confirm the part numbers listed are correct for 1,9 tdi pd150 ARL?
might be looking at second hand if can get some in decent nick
D.
Thai-wronghorse
Self proclaimed Cupra R addict & butcher!
Dec 3, 2015
2,199
1,038
Kent
Ripped from another site:
Part numbers...
COMPONENTS:
Intercooler*- 1J0145803H - apx £264 + VAT
MAP sensor*- 038906051A - apx £44 + VAT
PIPES:
Turbo boost hose - 1J0145828R or 1J0145822E (dep on chassis no) - apx £80 / £112 + VAT
Pancake pipe - 1J0145762BF - £88.54 + VAT
O/S*intercooler*boost hose - 1J0145834AA - £53.42 + VAT
N/S*intercooler*boost hose - 1J0145834AE - £35.95 + VAT
Plastic boost pipe runs from N/S boost hose to EGR boost hose - 1J0145770AB - apx £152 + VAT
EGR boost hose - 1J0145838AG - apx £44 + VAT
CLIPS:
Clips for red turbo boost pipe, 2 required - 1J0145769 - £1.11 + VAT
Clip for O/S boost hose to pancake pipe - 1J0145769A - £1.10 + VAT
Clip for*intercooler*to N/S & O/S boost hoses, 2 required - 1J0145769H - £0.84 + VAT
Clip for N/S boost hose to plastic boost pipe - 1J0145769G - £0.46 + VAT
Clip for EGR boost hose, 2 required - 1J0145769G - £0.46 + VAT
SEALS:
Seal for red turbo pipe, 43.95mm, 2 required - 3C0145117 - £3.67 + VAT
Seal for O/S & N/S boost hoses, 61.90mm, 3 required (2 for O/S and 1 for N/S) - 3C0145117H - £3.67 + VAT
Seal for N/S boost hose, 57,85mm, 1 required (fits smaller side of hose) - 3C0145117F - £4.92 + VAT
Seal for EGR boost hose, 57,85mm, 2 required - 3C0145117F - £4.92 + VAT
Additional info...
* hoses when bought new include seals
* pancake pipe when bought new comes with clips and mounting grommet
* there are 3 sizes of seals; small 43.95mm, medium 57,85mm and large 61.90mm
* revised seals; newer type seals are green in colour, the older were are black
* revised clips; original ones on turbo for example (1J0145769) had rounded edges which meant boost pipe could pop off, advise fit new version if you have original.
Sent from my HTC One_M8 using Tapatalk
Degsy
212
Merseyside
Wow look at the wear on couple of the old buckets that came off the car
