VAG-COM 409.1 on Windows 8
nangpae
hi guys,
i successfully installed VAG-COM 409.1 on Windows 8 with fully registered.
VAG-COM 409.1 KKL USB cable was used.
download cracked version by googling with "VAG-COM_409.1_crk_by_sht".
After install, if you see an error message that the Port Status is OK but the Interface is "Not Found", then just copy 3 files(d1.bin, d2.bin, d3.bin) to installed folder(c:\Program Files (x86)\VAG-COM).
it worked on windows 8, so i guess it works on windows 7, xp,... as well.
good luck.
747_727
1,113
Essex
It makes vag-com work as a fully registered version so you can save settings the only problem I found is that when you log on to any section eg engine the 3 dll files get deleted so you quickly have to re run the crack before it logs on for the crack to work.
nangpae did you have the same problem?
