either on the rear subframe bolt.. the big one you can see or on the rails that run down the sides under the car....
rear subframe bolt, Kwl cheers for that.
Was mainly wondering if some one had a picture with it highlighted as i found on another forum but on an Alfa.
Still Thanks for your help mate
never had that happen...i wouldnt trust brick more than decent quality axle stands at all...
2 bricks and some 2x4 have never failed me, i would 100% trust them getting under the car, unlike these buggers rated at 2 ton.
Bricks explode under pressure...
Looks like that axle stand wasn't used right.....
Wouldn't trust bricks or wood though
looking at those youll struggle with the subframe bolt mate, unless you use some thick wood to make it flat... ive got same as the ones that broke, different brant with flat top and work perfect every time for me...
not being an arse, but if you cant find the rear subframe bolt then should you be changing the brakes at all... as i said, not being a nob but......
meh not sure I agree with that. I couldn't point out rear subframe bolt but that doesn't mean once I've been shown I wouldn't be capable of upgrading my brakes.
If everyone thought like that then surely nooone would ever know anything?
Jack it up on the rear subframe bolt, then stick the axle stand under the end of the chassis rail running under the car.
Simples!
