madmatt1
122
Hi peeps im new to this forum,any way Hi, What it is i was looking forward to buying a nice cupra and doing bitts and bobs to it,and was looking forward to the nice dump valve psssst sound,but got off blower to jabbasport basically said not to bother due to engine management etc,thing is i had a cupra about 3 years ago fitted k and n filter and bailey dumpvalve,ok it did drink petrol and stall sometimes like at set of traffic lights etc,but i did have the pssttt sound which did turn heads :p ,but now peeps are saying to get a re-circulating 1 there soooo quiet thou :(, is there any kinda mod that will alloy u to fit the dump valve i want without buggering the car up?? cheers
Cold air inducion kit and a forge 007 recirv valve will give you a a noise, remap it and up the boost and that noise will get a lot more and very audiable outside the car. Should keep you smiling, although Dump valves are frowned upon on here, although back when Dump valves were new out i loved screaming around dumping all over the place in my Punto GT. But now you see people just taking the piss out of people psssshtting all over the place.
I have induction kit and standard bosch DV and you can hear an audiable noise outside the car though not as loud as a non recirc !!
Steer clear of the K&N filters as the oil they use can damage the MAF. Green panel filter or dynatwist are good.
they are over oiled at the factory,give them a good wash and "lightly" oil them and they are no better or worse than a green.over oil a green and they can fook the MAF just as easily as any other filter on the market
Ive got the old standard airbox back in now as it had a K&N filter in it, going to put a green panel filter in it instead but I cant hear the dump valve at all anymore, have found it to be a bit jerky also like it slows suddenly when you ease off the accelerator unless you ride the clutch?
Yeah I bought a new bosche one to rule out the DV as a boost leak as I couldn't afford a Forge one and the bosch brand new was only £13 !!
you will get problems in a short time again because they are not good for high pressure and in time you will buy a forge one ;)
not entierly true.some have run remapped cars with no problems at all.cupramax on this forum springs to mind,but most people change them
