A/F Ratios
bellautos
so is 13 over 1 lean
As quoted from pro drive member/worker.
12.9/1 is rich of stoich,
but it is also typically what we call LBT, or lean best torque
If you have 13/1 then the sums are not hard to work out :)
bentaw
Revo'd LCR
Oct 1, 2004
1,067
Hampshire
ok my lambda at idle is showing 0.9 and -7 in the 2 columns logged under 032 on vag com, then once on the motorway the columns read 0.8 and -5.5, what does this mean then.
According to rosstech that means i have slight vacume leak and my MAF is fubard or something else is fubard
wild willy
2,323
Wales
I've logged A/F ratio a number of times and never recorded negetive values.
I think you should only be concerned with the first column only.
wild willy
2,323
Wales
bentaw, you have a problem with your motor but you don't seem to be in a hurry to solve it. You may be risking potential damage. There must be another LCR owner in your area who you can swap parts off in an atempt to elliminate.
