APR or Bells Auto???
gtd86
Doctor of driving
Sep 9, 2006
159
www.batit.com
Right stuck in a dilema, getting remap...
Do i go for APR which is only half an hour away n costs £450
or
Bell auto custom map "Personal map on standard car, with adjustments to suite driving style and needs, a lot stronger than generic maps/tuning" which means a 3 1/2hour drive to york and petrol so working out about £345
Then i've got £100 extra to spend on carbonio...:)
RobM
Back from the dead...
Sep 27, 2006
4,982
Southampton
What other mods have you got on the car? Do you intend on doing any more?
Custom maps are excellent if your car is not otherwise standard, as they can adjust the map to take these into consideration. So on that basis, get everything else done first and then get the map.
Generic maps will be based on a few assumptions, like what exhaust and filter you have. These often have the ability to adapt a small amount to cater for any future 'bolt on' mods such as exhausts and filters.
gtd86
Doctor of driving
Sep 9, 2006
159
www.batit.com
hi, well apart from the forge recirc valve n then possibly the carbonio, so if i was going for the Bell auto one, i should buy the carbonio 1st?
RobM
Sep 27, 2006
4,982
Southampton
If you're going for a custom map then do the engine mods first, yeah. That way they can adjust it to make the most of the changes.
AwesomeSarah
Forum Sponsor
Mar 6, 2006
727
Oh blimey yes go down the route of APR as it comes with a FREE cup of tea ;)
But I would say that wouldn`t I ?
Sarah
gtd86
Doctor of driving
Sep 9, 2006
159
www.batit.com
lol, hi sarah, see i just don't know!!! the 3 1/2 hour driving doesn't bother me though, but then i would need to order my carbonio from awesome anyway, so kinda fair on both companies...:)
gtd86
Doctor of driving
Sep 9, 2006
159
www.batit.com
ok just looking at the website pricing scheme under bell auto, the 295 remap does not take mods into consideration....
Prices are as follows for the 1.9TDI (EDC15 ECU), 1.8T (Bosch ME7 ECU) and many more of the VAG range:
- Generic map loaded with NO adjustments slightly weaker power and torque than personal mapping is £250.00 all inc.
- Personal map on standard car, with adjustments to suite driving style and needs, a lot stronger than generic maps/tuning £295.00 all inc.
- Full custom writen map, with adjustments to suite modifications and driving style, a lot stronger than generic maps/tuning £345.00 all inc.
So it wouldn't matter if i put the carbonio on after the remap is done?!?!?!?
RobM
Sep 27, 2006
4,982
Southampton
No, in that case it's simply a generic map with minor alterations to suit the way it delivers power. The same sort of thing can be achieved on most maps and I'm sure APR is no different.
Dodson
Extreme Blue
Feb 9, 2005
610
Redcar
i have the bell auto map on my car and....it fooking flies mate.
I also have the Carbonio and forge DV.
look at results in my sig.
The torque reading is what vag com showed on test drive after the map
gtd86
Doctor of driving
Sep 9, 2006
159
www.batit.com
so in order to save money i should go with bell auto? is it worth while paying the extra £50 at bell auto to get it customed to my car?(if i put the carbonio in)
Dodson
Extreme Blue
Feb 9, 2005
610
Redcar
I personally would mate.
He sets it up and plays with the map to map the car to the mods that are on it.
gtd86
Doctor of driving
Sep 9, 2006
159
www.batit.com
ok bell auto it is then, get that done then order my carbonio, then order a bluetooth elm327 connector so i can connect with me pda...:)
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
Is he unable to reply?
Why does he think that you need a filter 1st?
It won't aid spool up, and won't limit maximum boost. All it will allow is about 5% more top end air flow, which won't be mapped to.... it'll just happen.
a tayloring of the map will go on where the timing correction & possibly the boost will be adjusted - but that's it....
I defy anyone to prove openly what difference an airfilter requires on a stage 1 map for an otherwise std car.
