TIP's
Forbez
Huge Member!
Feb 11, 2004
5,878
S.Wales
Visit site
Or simply trim with a stanley knife, easy.
Each to their own, I know when i was stood in a pit on a friday night with the car over my head, I had no 1/4" spacer.
Patrickw
Ordered my forge tip direct today!
Thankd Cordobabrendy for the discount idea, I mentioned cupranet and got the 10%:funk:
Forbez
Huge Member!
Feb 11, 2004
5,878
S.Wales
Visit site
Not knowing that i would need a 1/4" spacer, how could i prepare for that?
At the end of the day, mine is fitted, working fine, was trimmed a little, and i'm happy.
Both ways work fine, and arguing over the internet is pointless.
Patrickw
What 1/4 spacer? Doesd this not come with the forge kit?
beezaturbo
341
Staffordshire
no.
if just try and fit the tip as it is now you need to cut it down to get it past the water pipe. or unbolt the water pipe off the block then fit the tip but you need to refit the waterpipe to the block, so i just used a 1/4" washer/spacer between the bracket and the block then refitted the waterpipe.
godzuki
Mk2 cupra & golf mk2 20vt
Sep 11, 2006
231
Newcastle upon tyne
Just a quick question on this,
Does the forge TIP work on both a k03 & K03s ????
Just i have both & will be upgrading (don't want to have to buy 2 of them)
Thanks.
gavthelad
Bring on the Boooooost
Nov 19, 2005
1,394
Redditch (Midlands)
just to add to this........i trimmed mine about 10mm, there was absolutely no way it was gonna go on otherwise.
works a treat and is so much better than the standard one!!!
Patrickw
Just got my new forge tip! Is it supposed to come with a fitting kit (hose clamps etc.)?
Patrickw
Dammit! That means I have to order that and wait some more.
What fittings are in the kit, is it just screw up type hose clamps (jubilee clips)?
