how do you mean working Phil?
as in sync'd to the car or actually adjust the code properly?
i attempted to have go when i first got my cable cos i read on vortex the car didn't need to be remapped, but it wouldn't even sync with the car, reason unknown. didn't bother looking into it again. would be interested in using it instead of an SPS3 if anyone has used it
Its not to be used instead of the SPS. If your not sure how to use it dont bother as i can do more damage than good.
Carl, just wouldnt connect, uknown protocol.
yeah phil thats pretty much the problem i had, tbh i assumed it was my cable
fact is if you've never used it before then how will you ever learn.... i know i've probably put people off it before but thats cos i wouldnt want to be blamed for someones mistakes
since im more than IT literate and an avid car enthusiast. i did fancy having a pop at this
but like i said. wouldnt work for me
5 amp cream/brown looking fuse, number 26, its 2nd from left on top of the fuse board, on horizonally.
instrument fuse needs to be out on ibizas (crappy comms as usual on them)
custom settings is what I use, does same thing and works fine.
