depends which type but since this is in the mk3 section i guess you mean an AQX/AYP lump
in which case i'd be looking to spend between £500-£800
however tbh if i was going to buy one personally i'd either pick up a latter Golf lump AUM code i think or a BAM LCR lump and just remap it
reasons being...
if I was going BT i'd go for the golf lump since the stock turbo isn't relevant it doesn't matter what it comes with (k03s). prob around the same price as above 500-800
but if i was just fitting a lump and remapping for the standard turbo, might as work with the k04. looking at over a grand probably
The AYP engine dose have stronger internals than the golf and can handle BT with more conferdance, but as said if you are leaving the turbo standard i would go for the TT 225 or a leon cupra R as they come with a ko4 so with a remap will give you more power than the golf or ibiza.
reasons being...
Why would you want to buy a weaker AUM engine?
19mm pins and little rods.
you can buy mine if you want, 4,500 miles, complete, car was in a smash now mostley repaired for a grand, brand new yoko tyres in silver, give me a ring
0773 974 6372
i mean, you can have the whole car for that price, all parts there to put back on road or break, its silver 51 plate
got one for sale, with clocks, keys, ecu ect, the lot for a conversion
engine covered 28k
had metal water pump and cam belt, no turbo with it tho all the rest and still in car running
also have gear box with atb diff will sell seprate
