chris060685
Ibiza Cupra
Nov 6, 2005
101
dunstable
wired up a sub and amp in my ibiza but it doesnt work, the green light on the amp isnt lit, ive been told its the earth wire??? where do u put it? ive tried the rear seat bolt? but it wont work? do i need to disconnect the battery..
Check the earth, make sure its contacting bare metal of the bodywork, also check the positive is connected OK. Also - have you connected the 'Remote' cable to the headunit or a 5v supply?
ive connected the remote cable, and the connection to the positive of the battery is fine, ive tried the earth on bare metal but no green light. i cant see what else i can do? does the battery need to be disconnected before the earth is attached on bare metal?
I'm no expert, but its always something I'd recommend.
As said in other post, you should maybe check the fuse on the amp.
checked it its got a wire from head unit with a label saying rem.ok. but theres one that says p.cont? which is also blue????? maybe connect it to that one instead?
I would have thought "Rem" would be the correct one... you might want to check with one of the experts on here... I've only done the basics myself :)
try looping a bit of wire over from the battery positive on your amp to the remote and see if that turns it on....oh and p.cont is the wire you need ;)
just tried that and it still dont work??????? its not a dodgy amp as ive took it back, this is the second one? maybe the wiring is shite!!!!! is there anything else i could try?
