Firstly apologies if you have just read this elsewhere but I though I may get a broader range of answers here.
I need a little help in identifying what exactly the device in my pictures does and whether I should start getting worried about it as it has started buzzing loudly. It can be heard the car over the engine tone.
I believe it may something to do with the vacuum system on the car as several pipes lead to the air box, turbo, and the inlet mainfold. I know its not the vacuum pump itself as this is located on the side of the engine block and has a single larger pipe going to the brake servo.
It starts doing it when I am stuck in traffic so I am only moving at low speed but useing the brakes a lot.
What I have found is that when it is buzzing, if i pump the brake pedal 3/4 times it will stop, but if I'm still in the traffic it soons starts again.
The only other sympton I have noticed and I'm not sure if its related or not is that the ABS warning light occasionally comes back on again for a couple of seconds after starting, but it does go back off.
The car: Mk4 Ibiza, 1.9Tdi (100) on an 03 plate, and has covered 40,400 miles. Engine code is ATD if that is any help
Pic 1
Pic 2
Pic 1
Pic 2
