coilovers
BEOWULF
I am BEOWULF !!!
Mar 18, 2006
1,186
I AM IN FRONT OF YOU
Jamex mate i am quite sure that one side is lower than the over.
As i get a rubbing sound when i trun one way ant they wheel looks closer to the top then the other.
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
Not sure, try jacking up the car, then adjusting the front , then the rear, keeping an eye on how level.
RobM
Back from the dead...
Sep 27, 2006
4,982
Southampton
It's a bit crude... but you could simply set all four corners to their highest setting and then adjust them all down by the same amount of turns (or clicks, depending on setup) per corner.
Skorchio
600 Miles to a tank :)
Jan 23, 2007
1,570
Nr Milton Keynes
There ajustable - Ride hight and if you spendd more ajustable damping - There good because u dont have a fix lvl of drop so you can slam it as much as u want to suite your car.
Dec 19, 2006
673
oh right so what do coilovers replace then? the whole suspension or just the spring? Take it they can be used for the front and back suspension providing you get the correct fitting ones? i'm curious :D
BEOWULF
I am BEOWULF !!!
Mar 18, 2006
1,186
They replace the struts front and back and they are the best £600 quid i spent put them on myself just need to adjust them a bit as i put 18" wheels on and before it only had 16"
Dec 19, 2006
673
Sorry to hijack your thread with my questions, cheers for the answers though much appreciated :)
Dec 19, 2006
673
sweet cheers mate, do you know how much the springs lowered your car by or is that dependent on what you decided, does your front splitter scrape more now?
BEOWULF
I am BEOWULF !!!
Mar 18, 2006
1,186
some pics of mine
