Hi all.
Following a stint in the garage for braking diagnosis, I've been advised that it 'could' be the abs pump.
The symptoms are:- Front brakes bind on when warming up (within 10-15 mins they are seizing on), the brake pedal is firm when ignition on & before long, it's almost rock hard to press.
I had new brake lines, braided hoses & front pads replaced last year, leaving me with an un-driveable car.
I believe it's fully down to fluid pressure not returning, & all search results point towards a master cylinder compensation-port issue so I'm not sure about the conclusion. I feel like I can't get these tests done, just get possible ideas. The braking system was immaculate before the work, flawless braking, so could the abs pump be responsible if it was fine before?
I am more than happy to have a professional opinion, but it all seems like guess work. The garage said it wouldn't flag up on a diagnostic, it's too old, but I find this unusual (am I wrong?).
If anyone could help me in any way, is be so grateful. I don't want to fork out for an expensive pump, only to find that it's made no difference at all. Also, doesn't an abs pump need to be programmed to the car?
I'm very confused, so if you folks have any advice or questions, please throw them at me. Thank you!
