LCR 1.8T BAM
Hello, I have issues with STFT,
I have changed all vacuum hoses, TIP, stock DV, everything is good.
MAF and LAMDA are reading properly, even with MAF unplugged I have the same +25 STFT.
When I start the car STFT is 25%, doing misfires, after some time on idle it will settle down.
Another fault code i get even on idle is
When I remove the hose from the PCV that goes to the intake and install a new hose on the intake with a plug to seal the leak, the STFT is around -10%, and there is no fault code 17705 / P1297 / 004759 – Pressure Drop between Turbo and Throttle Valve (check D.V.!).
When I reconnect it as it should be and press the hose from the PCV to the intake with pliers, the STFT starts to drop.
I did suction pump delete, if needed i can get new one and put it all together.
Could all this be problem of PCV Bleeder Valve?
If PCV is bad, suggest replacement parts, i will try to get OEM tomorrow.
Thank you in advance.
