AceD909
58
13
LCR 1.8T BAM
Hello, I have issues with STFT,
I have changed all vacuum hoses, TIP, stock DV, everything is good.
MAF and LAMDA are reading properly, even with MAF unplugged I have the same +25 STFT.
When I start the car STFT is 25%, doing misfires, after some time on idle it will settle down.
Another fault code i get even on idle is
17705 / P1297 / 004759 – Pressure Drop between Turbo and Throttle Valve (check D.V.!).​
When I remove the hose from the PCV that goes to the intake and install a new hose on the intake with a plug to seal the leak, the STFT is around -10%, and there is no fault code 17705 / P1297 / 004759 – Pressure Drop between Turbo and Throttle Valve (check D.V.!).
When I reconnect it as it should be and press the hose from the PCV to the intake with pliers, the STFT starts to drop.
I did suction pump delete, if needed i can get new one and put it all together.
Could all this be problem of PCV Bleeder Valve?
If PCV is bad, suggest replacement parts, i will try to get OEM tomorrow.
Thank you in advance.
Whats the LTFT?
What's the short trims doing when driving?
Short trims are jumping around, going up to 20% and -10%.
LTFT was around 4.8%, but didn't check after the hose from charge pipe to n75 was replaced.
I don't have any boost right now, 0.3bar is max.
When the hose from charge pipe to n75 was leaking, I would get P1297 fault code and limp mode randomly, but the car was overboosting and fluctuating.
Now with hose replaced I can't even try.
I can check for STFT and LTFT in couple hours and will post the results
I have access to ME7LOGGER, just give me list
I'd smoke test it to try and sort the boost issue, then see what happens. No point worrying about STFT etc until you have that sorted.
I Work on my car right now, i disconnected pcv and put new hose to intake with bolt to stop leak, boost is very good, no P1297 code.
I did couple of times with smoke test, there is no leak, if I build more pressure smoke comes out of dipstick
In that case i would definitely try replacing the PCV valve.
I ordered new OEM from Porsche Macedonia, will get it in 5 days.
But i got overboost again, leaking hose to n75-wastegate? Cause i can hear hissing sound for sure
Smoke test or visual inspection are really the only ways to find that kind of leak. If you can hear hissing then must be something there.
As for the lack of boost, maybe you have some sort of fault with wastegate itself? Like not seating properly or occasionally sticking open. With the mods/deletes and with having rebuilt the turbo etc, you're probably best off just taking it to a specialist tuner who knows the 1.8t. Pay a couple of hours labour and get them to take a look at your setup or see if they can find the leak.
Some things to check
-DV test: remove it and put a finger on the nipple after you push the piston in. The piston should not move. If it moves, the DV is leaking
-Suction pump delete is fine, it helps with brake boost in low vacuum situations, but is a known source for leaks. Mine was leaking and I also deleted it. I used a wheel bolt to plug up the hole in the hose :)
-If you are running on 0.3 bar, you are driving on wastegate pressure. You can temporarily cap off the wastegate to see if you can build boost (be cautious!), so you can rule out the wastegate
-Check the N75, if I remember correctly: you can blow air through one hole, the others should remain closed (remove if from the car first). If all holes let air through, replace it
-Reset the fuel trims and drive around a while and report back
-Double check possible causes in the article below
