what car?
the jabba dp is single outlet so will not mate straight to the twin cat set up. might be worth getting a custom downpipe made which is flanged to mate with your dual cats?audi tt 225, so i'm guessing it will be the same as a S3 or Cupra R with a IHI right..?![]()
IHI vf34 $699 (<£400) from the US (google it)
Manifold-£500 (full price from jabba)
Oil and water lines <£100 from any hydraulics shop. (or pay jabba a little more)
Injectors-£200 (440cc from the US)
Maf tube-free
Pieces of silicon hose for turbo outlet, +maf to intake pipe joint-£15
Modified inlet pipe to fit turbo-£5
Fitting £300
I reckon thats £1520.
Still got to get it mapped though and do a little work yourself to work out the fittings you need.
You may also want to get an uprated fuel pump. The S3 one is £120 from the dealers, or you can source a non VAG one from the US for half that.
It just takes a bit of bottle to sort it out for yourself
Edited to say I forgot the turbo to downpipe adapter. Jabba charge £150 ish for theirs, but I'm sure you could get one from anyone making scooby exhausts for a lot less.
compressor wheel turned round to suit vag cars as they're designed for subarus.what do you mean by clocked?
