neuspeed 25mm front 28 mm rear
can't recommend this set up enough, loads of the mk3 guys use it, myself and Martin M use it on our mk2 20vt's and it makes the world of difference
add a set of 15mm rear spacers and it's a whole different car
will deffinatly corner alot better than standard that's for sure, mine goes where i point it now
15mm eibach hubcentrics on mine, back wheels do touch the arches over big bumps or under hard cornering (track days)
I've got exactly this setup with the spacers and give it a big thumbs up.
Only thing to be wary of is you need some substantial steel section to make a drop link bracket for the rear bar. I managed to break the first two sets and now using 5mm thick section. I've got a drawing I can send you if you are interested.
(sorry for my bad english :()
Following the differents threads for the ARB, I've order an Neuspeed for the front (25mm) and a 28mm for the rear.
I'm very interesting if you could send me your drawing.
Doug
Doug
Hi, if you send me a PM with your email address I'll send you a copy.
2 sets?
:confused:
