well im not 100% loyal as the engine is in a corrado im more interested in quarter mile, i will change the turbo eventually but im gunna wait till it blows im in no rush, are uprated fuel pressure regulators worth doing?
Exhaust (inc Downpipe & Sports CAT), CAI Filter, FMIC, 4 Bar FPR, Injectors and a Remap should see you to the 250 BHP... just... will set you up nicely for when the Turbo does pop its cloggs to, almost everything will already be in place for 300-350+ BHP
Unless you take it to a happy dyno of course...
as said 220bhp is realistic "real" bhp on the k03s fitted to your 180 motor.
Add bigger DP, free flowing induction, FMIC and you could eak out a little more (maybe up to 15bhp)
Unless you take it to a happy dyno of course...![]()
Eh? Why would you change the injectors on a standard turbo?
And the only thing you would probably keep if you went BT would be the FMIC, as you would use a different downpipe, MAF etc...
fmic, turbo back exhaust, TIP, filter, DV, remap and any other mods needed like 4var for revo stage 2.
Thanks for the help guys. Ive currently got a 2.5" downpipe and straight through system (no cats at all) with a landrover td5 intercooler but i havnt got a clue whether the intercooler will stand even 250bhp?? Are the k&n apollo air filters any good or do you reckomend any others and also what fuel pressure regulator is the best to go for? The car it self weights about a ton so isnt to bad and goes well even with the standard cupra engine
Only the FMIC???
So you wouldnt keep the CAI, 4Bar FPR, Exhaust, sports CAT and injectors!?!?!?!
Somehow i think you would
Admittedly the Downpipe and Map would be duplicated, but thats it, all the others are there as overkill to start so the step up to BT conversion is as small as possible (just Turbo/Mani/Downpipe/Remap required)
I will be trying to do it as i go to spread the financial burden of doing a BT conversion, just cant muster that sort of £££ in one go, lol
