adriaticman
141
essex
:cry:Thinking of getting Superchip bluefin, but 1st need to find port to plug it in. Is it under some secret cover? Cannot find it
Diag Plug
Hi,
There is a cover on the drivers side dash area, under headlamp switch, this pulls off, and the plug is behind it.
Regards,
Jochen.
Be interested to know how the DSG 'box copes with a remap, I'd be scared loading any unexpected torque and strains onto it and how the auto side of the gearbox copes with it, let us know how you get on, mate.
Rob
Rob
A mate has just had his A3 TDI S Line DSG remapped by Upsolute.
He requested for a lower torque map for the same reasons you are asking. I think the torque figure is 380Nm & he's had no problems so far.
Guess what! I cannot find any cover for the diagnostic port. Car 2007 model year Anyone who could provide a picture would be a star. I have pulled pushed and stuck my fingers behind all the panels and in every hole under the dash. Nothing
Hope I get a bit of luck
the cover that sits directly infron of your right knee to the ight of the steering coloumn it curves down to the left pull it at the top to release it
goble u are a star. Found it! Would never have guessed that the panel comes off in a million years. Now to find out why I have new tap tap noise n/s from cold inside car Goes as car warms up
they are all like that . nothing to worry about if it's the noise you mean its the heater flaps carrying out a learn procedure
It only started a few weeks ago. Have done 13,000 mls never happened before. Sounds like someone knocking to come in!! Also heard of any DSG issues with judder when changing gear from 1750rpm when gbox hot (dont do it as a habit). I have found that if in traffic and change fron 2nd to 3rd as manual change lets box select next gear judders lika a slipping old clutch
goble
Car due to go in soon to have bonnet insulation cover changed as going mouldy. Something to do with washers leaking water. Will get other issues checked out, but need to leave car overnight for tapping noise, then get gbox hot!! Can`t win.
Still have same now intermittant dashboard vibration from new and still not fixed. Average mpg still not reached 40, yet Seat UK say no fault found. Don`t intend to give up, as great car.
If things get fixed then Goodyear f1 Assymetrics to replace Pirelli P7 then Superfin, unless common rail 2.0 tdi release soon.
Thanks again for your help
Hope I get a bit of luck Thanks
Remove the cover,-1- located below the steering column, using the lever -U-30800-, acting on the points shown -arrows-.
etc. etc.
– With ignition switched off, connect the Vehicle Diagnosis, Testing and Information System -VAS 5051 A- to the vehicle diagnosis connector -arrow-using the diagnostic wire -VAS 5051/6A-.
– Switch ignition on
– Switch off all electrical components.
If you send me your pm I will email a word document
