C1TPT
256
St. Albans, hertfordshire
ive just got my cable and thought i would do some logs but i only got time to do one log from each channel (115 and 118)
115:
Code:
Wednesday,30,January,2008,15:42:07
6K0 906 032 ,1.8L R4/20VT SEA    0002,
Group A:,'115, Group B:, Not Running, Group C:, Not Running
RPM,Load,Absolute Pres,Absolute Pres
STAMP,  /min,       %,        mbar,      mbar,
0.39,     2400,    89.5,    2210.0,     1180.0
0.79,     2440,   106.0,    2000.0,     1430.0
1.28,     2520,   123.3,    2300.0,     1710.0
1.68,     2600,   133.8,    2280.0,     1860.0
2.08,     2720,   139.8,    2240.0,     1970.0
2.58,     2800,   142.9,    2210.0,     2050.0
2.98,     2920,   148.1,    2190.0,     2110.0
3.49,     3040,   153.4,    2160.0,     2140.0
3.87,     3120,   154.1,    2160.0,     2180.0
4.27,     3240,   154.9,    2150.0,     2190.0
4.67,     3320,   151.9,    2140.0,     2160.0
5.07,     3400,   150.4,    2130.0,     2130.0
5.47,     3520,   148.1,    2110.0,     2110.0
5.87,     3600,   145.9,    2110.0,     2100.0
6.27,     3680,   146.6,    2100.0,     2100.0
6.67,     3800,   145.9,    2100.0,     2090.0
7.07,     3880,   145.9,    2100.0,     2080.0
7.47,     3960,   147.4,    2100.0,     2090.0
7.87,     4040,   145.9,    2090.0,     2080.0
8.27,     4160,   146.6,    2080.0,     2070.0
8.67,     4240,   147.4,    2080.0,     2060.0
9.07,     4320,   147.4,    2070.0,     2050.0
9.47,     4400,   148.9,    2070.0,     2040.0
9.87,     4480,   148.1,    2070.0,     2050.0
10.27,    4560,   146.6,    2060.0,     2040.0
10.67,    4640,   144.4,    2040.0,     2020.0
11.09,    4720,   143.6,    2040.0,     2000.0
11.58,    4800,   142.9,    2030.0,     1980.0
11.98,    4880,   142.1,    2020.0,     1950.0
12.38,    4960,   140.6,    2020.0,     1920.0
12.78,    5000,   139.1,    2020.0,     1910.0
13.28,    5080,   138.3,    2040.0,     1900.0
13.68,    5160,   136.1,    2040.0,     1890.0
14.18,    5240,   135.3,    2050.0,     1860.0
14.58,    5280,   133.1,    2060.0,     1860.0
14.98,    5360,   133.1,    2070.0,     1860.0
15.38,    5400,   129.3,    2070.0,     1860.0
15.78,    5440,   128.6,    2080.0,     1820.0
16.17,    5520,   127.1,    2080.0,     1840.0
16.69,    5560,   126.3,    2090.0,     1820.0
17.09,    5600,   125.6,    2100.0,     1800.0
17.57,    5640,   125.6,    2090.0,     1790.0
17.97,    5680,   123.3,    2100.0,     1790.0
18.37,    5760,   122.6,    2100.0,     1770.0
18.78,    5800,   121.8,    2110.0,     1770.0
19.28,    5840,   121.1,    2120.0,     1750.0
19.68,    5880,   121.1,    2120.0,     1740.0
20.08,    5920,   121.1,    2130.0,     1730.0
20.48,    5960,   118.8,    2140.0,     1740.0
20.88,    6000,   118.8,    2140.0,     1700.0
21.28,    6040,   117.3,    2140.0,     1700.0
21.68,    6080,   117.3,    2140.0,     1690.0
22.08,    6120,   116.5,    2140.0,     1680.0
22.48,    6160,   116.5,    2140.0,     1680.0
22.88,    5760,   23.3,     1010.0,     1410.0
23.28,    4960,   7.5,      1010.0,     1200.0
23.68,    4280,   8.3,      1010.0,     1120.0
24.08,    3600,   9.8,      1010.0,     1090.0
118:
Code:
Wednesday,30,January,2008,15:39:15
6K0 906 032   1.8L R4/20VT SEA    0002,
Group A:,'118, Group B:, Not Running, Group C:, Not Running
RPM, Temperature, Load, Absolute Pres.
TIME
STAMP,	/min,	°C,	%, 	mbar,
0.00,	2320,	27.0,	0.0,	1040.0
0.40,	2320,	27.0,	0.0,	1040.0
0.80,	2360,	26.0,	85.9,	1050.0
1.30,	2440,	24.0,	80.0,	1340.0
1.70,	2480,	23.0,	79.6,	1550.0
2.10,	2600,	21.0,	79.2,	1720.0
2.50,	2680,	20.0,	85.9,	1860.0
3.01,	2760,	19.0,	80.8,	1980.0
3.41,	2880,	18.0,	83.1,	2040.0
3.90,	3000,	18.0,	85.9,	2120.0
4.30,	3080,	18.0,	85.9,	2160.0
4.80,	3240,	18.0,	83.1,	2210.0
5.29,	3360,	18.0,	82.4,	2140.0
5.69,	3440,	18.0,	82.7,	2120.0
6.21,	3600,	18.0,	82.7,	2110.0
6.59,	3680,	18.0,	82.7,	2110.0
6.99,	3760,	18.0,	83.1,	2100.0
7.39,	3880,	19.0,	83.1,	2100.0
7.79,	4000,	20.0,	83.1,	2080.0
8.21,	4080,	20.0,	83.5,	2080.0
8.59,	4160,	21.0,	84.3,	2070.0
8.99,	4280,	21.0,	84.7,	2060.0
9.39,	4360,	21.0,	85.5,	2050.0
9.79,	4480,	21.0,	85.9,	2050.0
10.19,	4560,	21.0,	85.9,	2050.0
10.59,	4640,	22.0,	85.9,	2030.0
10.99,	4720,	23.0,	85.9,	2000.0
11.41,	4800,	23.0,	85.9,	2000.0
11.90,	4920,	24.0,	85.9,	1950.0
12.30,	5000,	24.0,	85.9,	1930.0
12.70,	5040,	24.0,	85.9,	1900.0
13.10,	5120,	24.0,	85.9,	1890.0
13.50,	5200,	24.0,	85.9,	1870.0
14.00,	5280,	25.0,	85.9,	1860.0
14.40,	5360,	26.0,	85.9,	1850.0
14.80,	5440,	26.0,	85.9,	1850.0
15.29,	5480,	26.0,	85.9,	1820.0
15.71,	5560,	27.0,	85.9,	1850.0
16.19,	5640,	27.0,	85.9,	1810.0
16.70,	5720,	27.0,	85.9,	1790.0
17.10,	5760,	27.0,	85.9,	1770.0
17.50,	5840,	27.0,	85.9,	1770.0
18.00,	5880,	27.0,	85.9,	1750.0
18.40,	5920,	27.0,	85.9,	1740.0
18.80,	5240,	26.0,	0.0,	1320.0
19.20,	4520,	27.0,	0.0,	1180.0
19.60,	3880,	27.0,	0.0,	1110.0
20.09,	3080,	27.0,	0.0,	1080.0
20.49,	2440,	27.0,	0.0,	1070.0
20.89,	1840,	27.0,	0.0,	1060.0
21.39,	1280,	27.0,	0.0,	1040.0
im not sure on what the boost (channel 115) should look like so not sure if its good or not, thoughts?? :)
cheers
boost looks alright to me
intake tamps look alright to me, what was the outside temp?
will be interesting come summer
you need to log further up the revs, say from 2k to 6.5k
try and do a couple of runs as well :)
p.s, you should have just added this to your other thread instaed of creating a new one so info is all in the same place :whistle:
How good are you at setting up revo software david as i need help logging mine and setting it up, as your only up the road thought i would ask ;)
not alot to be honest, never had revo
from reading though it shouldnt be too difficult using lemmiwinks
get some logs, adjust slightly, relog, adjust slighty, relog and so on
let me know if you wanna have a crack at it (pm if you want)
ok ill get some more logs done and take it right to the red line, then add them to my other post;) lol. the temp was 10.5 pretty much the same as the last logs i did. is it the closer the 2 sets of numbers are the better in other words actual boost vs requested boost (after the turbo kicks in)?
cheers
if you look on the 115 log
the left "absolute pressure" is what your ecu is requesting
the right "absolute pressure" is what your car is producing
Ok cheers david im off down to dubsport on saturday and they said they are going to upgrade the stage 2 version of my software to the latest one free of charge so if he doesnt set it up for me ill give you a shout :)
I doubt he will set it up for you as that would take abit of time, he`d proberly just set it back to the previous settings you had before. Your going to need a SPS3 to set it up properly then you can 'tweek' the timing with lemmiwinks.
i have an sps3, whats lemmiwinks tho seen you mention that the other day never heard of it before ?
Its a small free program that can be used to make quite a few adustments to the car fuel trims timing etc.... Ive only ever used it for timing mind.
Just had a search for lemmiwinks and found it can muck up your car if not used right so i downloaded it but ill get use to vagcom and understanding all the bits of logging before i use it
Went down to dubsport today to have the software updated and they said they couldnt read the ecu, they could change the boost ect but the ecu wouldnt let them in so he's having to speak to revo kev on monday :(
anyone else had this in the past or heard of it with revo software
tell me about it been trying to get my revo setup correclt for ages but car just aint running right.
is dubsport still open been trying to speak to them for ages cant get hold of them.
yes mate there still open, closed today at 2 but will be back open monday morning
