Air Box - dumb question
mikeruss
Cupra R
Dec 30, 2007
74
Hi All
About to buy a new filter and went to have a practise removal of the paper filter. Now, I removed the two black screws at the back and hoped that was it but the intake/MAF pipe was still appeared to be attached. I was to nervouse about taking it all apart. Any advise/pics on opening the airbox. Or is it just the two scews and I need to use a bit more force to lift.
P.S. it's a 55 Cupra R.
Before the Search Police start. I have searched ;-)
Gnollins
Bosh!
Jul 24, 2006
406
Yarnton, Oxfordshire
The top of the airbox doesn't come completely off. Take out the two screws and unhook the front of the airbox from the plastic lugs. You should be able to angle it up enough to get the filter out.
D.K
LCR 225
Oct 24, 2007
6,408
se london
If you undo the jubilee clip that holds the TIP to the MAF and pull the TIP off first it will be a lot easyer
ChrisGTL
'Awesome' LCR225
Nov 17, 2007
2,459
Huddersfield
Unscrew the two screws (Yellow)
Pull the cover up and push away from you at the same time, those red lines are where the tabs are holding the non-screw side down.
Hope this helps....
mark_1
Hi All
Have the same problem when I went to look at removing it, so this thread has just helped:clap:
Oct 17, 2006
1,015
northwest
not building a picture that makes sense
so air comes through normal but will be taken away to cat? or it comes from the cat warmer ?
those damn emissions tw@ts make everything confusing
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
the pipe comes from the airbox, sucked in through the sai pump, it whines on start up, then to the kombi valve on its way to the cat....
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
When engine is cold extra air is added to the extra rich exhaust gases to clean them and the process helps get the cat up to temp quicker.
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
The actual pump blows cold air and I can't see how blowing cold air into a hot exhaust helps it warm up quicker but I'm not going to argue with you two :cartman:
