Oh well atlest when a search is carried out from now on a prop thread description name will come up. lol
Well it isnt low on coolant and the red light was flashing? i cleaned the prongs and as a few other people suggested it cleared the fault.![]()
![Furious [:@] [:@]](/forums/styles/seatcupra/oldforumsmileys/furious.gif)
Took it bask to steelers today, apparently the sensor is situated high in the washer fluid tank so they topped it up over the sensor.
I asked if this would be a problem when the engine reached 90 degrees - he said no, I hope he's right!!!![]()
mine was doing it everyday, then i scrapped the prongs, had not done it since and not even today.
However, after some discussions on another thread, we thought it may be the contacts on the sensor, so if anyone feels helpful can they try taking the sensor plug off and on and giving it a wiggle to see if this helps.
Or...
wiggle but dont scrape the prongs...
thanks!![]()
been watching this thread as mine has the same problem... can someone point me to where these prongs are that need scraping? i'm crap with mechanical stuff!
guys, i need further help with this problem - in short my water pump bust so i got the warning and overheating engine. I have replaced the pump and the collant system is working fine however when i start the engine (even if its stone cold) or indeed simply when i turn on the electrics and not the igniton at all, i get the 3 beeps and warning light, it does it every time i drive!
i have replaced the header tank as was an easy 2 min job and have replaced the coolant temp sensopr and still no joy, any ideas?
would that be behind the water bottle for the washer jets?
I've just read this and havent had a chance to pop the hood yet.
