my advice........
Rip out all pipework from the outlet of the cooler
run fresh pipework from cooler under subframe and up to Throttle body - weld on MAP sensor from forge before Throttle body, abouta foot down the pipe
the way you have it set up at the mo your samco hose connects to a black squashed oe pipe, you may as well run all your pipes squashed if your doing this as your causing a bottleneck in flow
hope this helps
hope this helps
