R4cup
Beef NO Burger
Jul 28, 2006
1,749
In the garage
I now have the above fitted 2 my ibiza 1.8t & wot a difference it makes through the gears BUT i am very concerned with the slight rattle i hear as i pull off coming from the box:confused: is this normal & also i feel i may need new/uprated engine mounts as when i shift the engine feels like its been jolted. Wots everyones experience with having these fitted? What did u notice?
rattle normal on idle - input shaft chatter. Does it go away when you depress clutch? (posisble release bearing loose/worn)
single mass flywheel now from dual mass.
There is no ratte on idle, only when i pull off between 1.5rev - 2
would release bearing come with clutch or flywheel?
depends on make and supplier
Spec do, but I dont rate their release bearings and would use OE myself.
is the noise with foot on clutch or when clutch is engaged? (foot off clutch)
is it just during takeup you hear this?
if he got what i did bill then its the luk kit which came with it. I gave him the part no's to get it all. I haven't had any issues with mine. Touch wood!
