G60 flywheel & VR6 clutch
R4cup
Beef NO Burger
Jul 28, 2006
1,757
In the garage
I now have the above fitted 2 my ibiza 1.8t & wot a difference it makes through the gears BUT i am very concerned with the slight rattle i hear as i pull off coming from the box:confused: is this normal & also i feel i may need new/uprated engine mounts as when i shift the engine feels like its been jolted. Wots everyones experience with having these fitted? What did u notice?
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
rattle normal on idle - input shaft chatter. Does it go away when you depress clutch? (posisble release bearing loose/worn)
single mass flywheel now from dual mass.
R4cup
Beef NO Burger
Jul 28, 2006
1,757
In the garage
There is no ratte on idle, only when i pull off between 1.5rev - 2
would release bearing come with clutch or flywheel?
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
depends on make and supplier
Spec do, but I dont rate their release bearings and would use OE myself.
is the noise with foot on clutch or when clutch is engaged? (foot off clutch)
is it just during takeup you hear this?
Dec 3, 2007
2,475
cardiff
if he got what i did bill then its the luk kit which came with it. I gave him the part no's to get it all. I haven't had any issues with mine. Touch wood!
