Is that going by the trip computer? Mine regularly says close to 60mpg on that but when i work it out from fill up to fill up its more like 50mpg on motorways and 43mpg round towns.
There is a MPG fix.
VAG-COM
Go to [SELECT] followed by [17-Instruments] then [Adaptation-10]. Change the value for Channel 3 (default is 100). People who have been trialing different values seem to be sticking with 113 or 114. (+1 number = -1% change)
Once you have adjusted your value, select [Test] followed by [Save].
This reduces the MPG counter by 13/14%.
ChrisGTL,
Do I understand this to make it more accurate?
Otherwise, what is gain from the changes?
Chris, I tried that and it just said Channel 03 wasn't available? Do I need a login code first? I could get to some of the other channels (I could read 02, which was zero, and I could read one about the 10 mark which claimed to be a kilometre readout, that was on 14,000+).
Yaaayy The price of diesel is coming down....but what about next time??? its time you non-PD engined people looked at some of my posts about straight cooking oil (supermarket - straight off the shelf)(if u can buy it cash and carry you are laughing. Just had cause to have my injectors tested...this is after 2 yrs on straight cooking oil with maybe one fill up every 5/6 months with diesel...specialist diesel place tested the injectors and said " a bit dirty, but spray pattern is absolutely fine (they looked surprised when I mentioned the 2 yrs on cooking oil!) Again I say...forget these people who will try to sell you special fuel heaters (unless you live on Skye etc) and second tanks - all costing hundreds of pounds, I just put it straight in the tank (110 TDI 99 Reg) I get around the same mpg the same performance and the engine has a more subdued buuurrry sound....so just try it, even if you only keep the idea in the back of yr head for an emergency when you just can,t get Diesel and you have to take a life or death to hospital...you will be surprised.
There is a MPG fix.
VAG-COM
Toledo Steve said:Just had cause to have my injectors tested...this is after 2 yrs on straight cooking oil with maybe one fill up every 5/6 months with diesel...specialist diesel place tested the injectors and said " a bit dirty, but spray pattern is absolutely fine (they looked surprised when I mentioned the 2 yrs on cooking oil!) Again I say...forget these people who will try to sell you special fuel heaters (unless you live on Skye etc) and second tanks - all costing hundreds of pounds, I just put it straight in the tank (110 TDI 99 Reg) I get around the same mpg the same performance and the engine has a more subdued buuurrry sound....so just try it, even if you only keep the idea in the back of yr head for an emergency when you just can,t get Diesel and you have to take a life or death to hospital...you will be surprised.
good to hear. i wonder what tornado-red would say about that.
Arrggh!!! Tornado Red...my Nemesis......but he does have a point..if it had all gone wrong and I lived in a place where TDIs cost a lot or are hard to obtain 2nd hand, then I would have been risking a lot....but as it turns out...you all get the benefit of my experiments during which, I took all the risks, but not much of a one....as I said I have been experimenting for many years and not lost or seriously damaged an engine yet. Don,t forget that Diesel himself was designing an engine to run on alternatives such as groundnut oil.
