Left Foot Braking
strugers1
but then if your having to get back any unersteer by using the brake to make the rear en go light and bringing the rear end out your going to lose rpm and come out the corner slower!!!
but i know the brake and gas should never be applied at the same time
look the the old skool wrc drivers never two at a time
unles your heal/toe braking to rev match!!
DannyC87
Rubbing is Racing :-)
Mar 4, 2008
3,459
DannyC87
Mar 4, 2008
3,459
very impressive; he is using left foot braking for the first reason in the video I posted, the second reason; ie dragging the brakes round corners to keep the front in check is not applicable to 4wd and rwd cars so wouldn't be necessary in this case.
helms
Console Race Car Driver
Jan 30, 2005
492
Basingstoke
left foot braking is used as mentioned to bring in understeer, but you can do that also (not as immediatly mind) by just letting off throttle slightly.
The main reason for left foot braking, is to keep revs higher, meaning better exit from the corner.
The Audi Quatro was the main car that required left foot braking, because the turbo lag was so discusting, you needed to keep the turbo spinning with the throttle even while slowing down, otherwise it died on the exit. As mentioned, left foot braking was created in the twisty forest rallies, with the group N monsters like the quatro etc.
helms
Jan 30, 2005
492
Basingstoke
Bill, you would use left foot braking to stop understeer, perhaps encourage oversteer yes. By "bring in" i meant, control, or reduce.
And yes sorry I did mean group B rally cars, not group N.
BCM
Keyboard Gangster
Feb 1, 2005
2,680
Wishaw, North Lanarkshire
Ah, by bring in overstear i thot you meant introduce it
clear now.
But the whole point of it is to not let of the throttle. So thats that idea out the window.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
I know what lfb is - I do it :D
bring in understeer is'nt what it does tho.. ;)
quite the opposite
6th.replicant
698
9
London
Another benefit of left-foot braking is the taming of lift-off oversteer (which is rather useful when driving a pre-996 911 :cartman:).
