Nope
Sadly its a fairly simple answer. You hotter the cams you fit, the more power you get at the top end, but sadly the more lower down torque you lose.
The basic reason for this is, in order to get more power, you open the valves further and for longer to allow the increased volume of charge into and out of the cylinders. This is good at the higher RPM where it is designed to work, now when your down at the lower rpm, the inlet manifold preasure is lower due to the greater overlap with hotter cams, so the car runs more lumpy than standard and it takes more rpm to get the flow right and the engine to run smooth.
Now, im not saying that all cams will make your car run rough and lose lots of power at the lower RPM when fitted, its very important to fit the right cams in the right application and ones that compliment the modifications you have. F1 and touring car for example have very very hot cams because they need lots of power and they are prepared to go to the higher rpms to get it. As they dont use the lower rpm during a race they dont need the power down low so they are prepared to sacrifice it in order to get power where they need it. Now on the flip side, you have WRC. They are limited to 300bhp so what they want is to get as much torque as possible and the widest powerband, in order to get this they run low lift, and low duration profiles to get their goal, to them, their is no point in having 300bhp at 9000rpm when they can have it at say 5000 - 6000rpm and bucket loads of torque.
Its very much about choosing the right cams for the right application.
We offer 3 off the shelf profiles to try and cover most of these applications.
Fast road - for cars that want to keep std turbo but have exhausted most other mods and want more still. You will lose a little low down power but with good mapping (as in all cases) it will still be drivable and worth the gains.
Ultimate road - for cars with either standard turbo (and really wanting every bhp possible) or big turbo cars that want to get that extra flow into the engines better. In BT applications these act like fast road cams. A lose in lower down power is unavoidable but if you have gone to the effort of big turbo or full on little turbo and still want more power then it is again worth the gain.
Competition/Track day - For use on non road going cars where lots of power is the goal, these will work exceptionally well at moving you at high speed in the right engine. They are quite hot and as such do lose quite a bit of your low down power but the gains at the top end make it far worth it
Like everything tho, its a very subjective subject. Its a bit like someone who normally drives a diesel car then driving a petrol car, he would say "gosh, their is no low down torque at all" but he would not probably say that the car was undriveable. Someone on the other hand might. Its a bit like our exhausts, at what point would you call it loud?
i hope this answers your question and helps anyone else who reads this
Kind Regards
Garry
Product Development Dept
