ihi removal
dicko's
350bhp IHI Ibiza
Aug 5, 2008
240
Hartlepool
hi can anybody give me any hints or tips to remove the ihi turbo and manifold from my ibiza? And what sort of time scale to do it?
Could really do with the info A.S.A.P
Cheers lee
Wilko
Badge snob
drivers side driveshaft out. (hub nut, bottom bj, gearbox drive flange)
Downpipe off
oil return and water feed and return off (drain water)
split turbo hotside housing from turbo
remove oil feed line from bearing housing, and drop turbo off.
Remove turbo hotside from mani.
Unbolt manifold from head.
If these are not enough, you shouldn't be doing it
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
abysmal to spanner one of these. I wish you all the best.
expect to find some less than flat surfaces and look for cracks around the collector area. mine was riddled with them.
