This turbo any good for lcr
paul-murphys
efr 6758 here i come
HI GUYS IM AFTER A NEW TURBO FOT MY CAR AS I WANT TO SEE 300BHP+ DOES ANYONE NO IF THIS TURBO OFF EBAY WILL BE ANY GOOD OR HAS ANYONE USED THIS TYPE OFF TURBO.... LOOKIN AT ABOUT £300 FOR A HYBRID T28 KO4...... IS THIS TURBO GOIN TO BE RUBBISH AN BREAK.... HERE IS SOME INFORMATION ABOUT IT
TITLE
VW 1.8t Upgrade Turbo Hybrid T28 50 Trim Bolt on
APPLICATION
Bolt on to VW Golf/Jetta 1.8T Exhaust Manifold, downpipe
Modification required for compressor inlet,outlet
DESCRIPTION
3" Inlet Diameter
2" Outlet Diameter
Journal Bearing - Wet Float Type
T28 Flange
4 Bolt 3", Bolt direct to Downpipe
Oil Lub/Cool
350 HP Capable
Compressor Wheel
0.50 A/R Cold Side
Ind: 45 mm
Exd: 60 mm
Trim: 45
Turbiner Wheel
0.86 5-Bolt Standard Hot Side
Ind: 52.9 mm
Exd: 45.47 mm
DOES THIS SOUND OK???
LINK BELOW
http://cgi.ebay.com/ebaymotors/ws/e...0285164971&sspagename=STRK:MEWAX:IT&viewitem=
I NO WILL HAVE TO HAVE NEW REMAP BUT WANT TO NO IF THIS TURBO IS ANY GOOD... CHEERS GUYS
jamiebennett81
TITLE
APPLICATION
DESCRIPTION
3" Inlet Diameter
2" Outlet Diameter
T28 Flange
Oil Lub/Cool
350 HP Capable
Compressor Wheel
0.50 A/R Cold Side
Ind: 45 mm
Exd: 60 mm
Trim: 45
Turbiner Wheel
Ind: 52.9 mm
Exd: 45.47 mm
LINK BELOW
no no and no
cheap EBAY crap, that will melt and crack in the space of 5 mins
its cheap for a good reason, because it wont last and is very poor quality
Ruddmeister
Everything in Moderation
Jun 23, 2003
8,218
Weston-super-Mare
en.wikipedia.org
Nitrous would be your only option on that budget for north of 300bhp, JBS do progressive kits
Otherwise 270 to 280bhp is about the ceiling without budgeting circa £3k IMO for a half decent Big turbo conversion. Your £1k budget is too small to do Big Turbo properly e.g exhaust, downpipe, FMIC, turbo, manifold etc etc
You could spend the £1k on suspension mod's so it goes round corners :shrug:
jamiebennett81
go cheap....and watch you engine blow
there is not a turbo conversion out there that can be done proffessionally for under 1k, it aint gunna happen fella
if you have 1k, invest it in some ARB's and coilovers and save for a decent turbo conversion
anyone who informs you that you can do a turbo conversion for under 1k is either mad or just plain stupid
take it from one who has done the k03s conversion and a gt2x conversion on an Ibiza and a Leon, and is about to step into the realm of proper big turbo territory, which is easily 4k+
jamiebennett81
ok guys thanks for help. What about backdraft hybrid are they ok. I am after arb's an was thinkin of s3 strut. They any good. Thanks for help
BDMS hybrid turbo will be fine mate
ARB's are by far one of the best mods you can do
I run the Neuspeed 25mm front ARB and Neuspeed 28mm rear ARB, the best mod I have done to date
jamiebennett81
i.m sure i read backdraft turbo is about 1200 an read thats good for 320 is this correct? I will get arb are easy to fit.
I doubt you will get 320 by just doing the turbo
you will also need bigger downpipe, race cat, FMIC, induction kit and of course remap
again 3k at least
jamiebennett81
Nitrous is a serious option, worked well for M1tchy
IIRC circa 340bhp and around 400Lbsft
It's not for evreyone though :shrug:
on a standard head and turbo?
how well does it work and what cause does it have to the longevity to the engine/turbo out of interest?
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
Yep.
Worked well enough, as long as whoever was driving it didn't bring it in too early... :whistle:
jamiebennett81
Think m1tchy drove 30k+ miles with Revo remap and Nitrous.
No issues AFAIK not even the clutch, plenty of threads on it.
JBS progressive Nitrous injector is a good bit of kit though
excellent:)
pj1985
1.8T Power
Oct 31, 2006
2,218
Hampshire/Surrey
Nitrous is great if set up correctly. Power only lasts as long as the bottle though! Heard one story which makes me think having the bottle in the boot isnt the best place for it. Many myths about it around to get through before you get down to the core facts aswell.
caney
600
ran nitrous on my TT for five years with very good results! made 350bhp/409ftlbs with a ko4+75shot.Also made 415bhp/398ftlbs with ihi turbo+50shot.Melted 2 plugs and 2 valves which went out through the turbo back in April so i took it off!Turned out there were a few issues with the engine especially the cylinder head that could of caused it but i didn't want to risk it anymore but boy does it work well[B)]
cupraslayer
I want more bhp
Feb 8, 2008
1,543
northampton
so are you saying its not the best thing to do then?
