I had a similar problem on my Mk1 Leon, after rain fall the footwells on the drivers side and passenger side were soaking wet to the fact that there was puddles of water underneath and this was going back into the rear footwells. It was only after the thing conked out on me doing 70mph down the motor way I decided to get it checked out Turns out that the seal from the engine to the electrics behind the dash etc had failed and loads of water was coming in and dripping on the electrics. My advice would be have a feel under neath the front paneling to see if its wet under there and take it to SEAT they will do a water test on the car! cos dyou dont want the thig cutting out on you, let me say when it happened to me my pant were a lot browner in colour!!!!
I had about a litre of water come in once when I hit a really deep puddle onto the passenger foot well. I have rubber mats so it was obvious.. but it could be a hang over from a deep puddle. Not found out where it comes from .. maybe A/C drains etc?
Both! I got to them from the inside but there go through the floor pan. Got the same problem fella?
yep:(
only found out today.
its been dry around here for a week, but we had a lot of snow etc for the 2 weeks prior to that.
briefly felt around and can't pin point an entry point from either a door seal or the bulk head.
not going to get a proper look until Sunday, driving 370 mile round trip down to Kent and back on Saturday though :whistle: fingers crossed :blink:
rather be able to fix it without lifting the carpet.......
yep:(
The underlay takes SO long to dry out. I had the carpet up for weeks, tried drying it with a hairdryer everynight for literally hours. In the end I cut out the wet bit and hung it on the washing line.
I only noticed i had a leak when I hoovered the car and waves were being made where the water was being sucked up. :lol:
Didn't smell bad or anything!
Hope you get it sorted...
i'll check everything first but it sounds like the carpets coming up eventually though :(
I had a huge puddle in the rear passenger footwell too, but also found that the front passenger carpets (and everything underneath) was soaking wet. Took ages to find the leaks but eventually found two - one from the grommet under the scuttle tray (plenty of silicone sealed that up a treat) and another from the passenger door. It wasnt the door itself not sealing against the body, but the inner door under the door card. Once the door card was off, it was clear to see it had always leaked! Obviously the numpty who fitted the door inner was drunk and had dropped it, as the front bottom corner was bent and the foam rubber seal not even touching. Everytime it rained, water ran inside the door as it is supposed to, but also ran out just under the front left speaker. The only reason I noticed this leak was when I was a passenger, and noticed the rubber seal attached to the car body was wet - but had never noticed this on the drivers side.
When I had taken out the passenger seat and rear seats, took off a fair bit of trim to pull the carpet up and saw how sodden the underlay was - and realised how pointless it was using my hairdryer to try and dry it out as I had been!! I couldnt be ar$ed to take up all the carpet, so raised it was much as possible...took a stanley knife and fresh blade, and cut a huge section out! Brutal I know, but it would never be a problem once the carpet was refitted. I left the carpet in my workshop and it took about 3 days to fully dry! To make sure that the rest of the car was dry underneath, I took some 40mm flexi ducting (just happened to have 25m reel in the workshop), cut a load of slots along its length, fashioned a connector and plugged it into the far left passenger airvent (after removing it first...obviously) and then ran it under the carpet in all directions. I couldnt really drive around with the carpet all in the air, so this seemed the most sensible solution. Everytime I drove too and from work, I just closed all but one vent, and directed everything down the ducting. It worked a treat! It did like a little like I'd trapped Doctor Octopus under the carpet - but meh!
The one good thing to come from all this, was that I was finally able to cure the annoying rattles in the passenger door when listening to music. Dynomatting both doors does make a hell of a difference to the sound - better, tighter bass in my opinion!
leak
any thoughts where this waters coming from?
picasaweb.google.co.uk/kthhrv833/Leak
its filling up my passenger side footwells :cry:
thx
keith
coincidentely......i've been meaning to post in this thread :rolleyes:
i think i've found the area of origin of my leak.
noticed the other day after heavy rainfall the front passenger footwell was wet.
had a feel around under the dashboard, felt a drip on the edge of the plastics.
got a finger in a gap and on the inside there is a foam panel in the back of the panel to the underside of the glovebox.
removed this and the foam is soaking!
removed panel and squeezed most of the water out and stuck in the airing cupboard to dry out.
the puzzling thing is i've checked the likely source, the pollen filter....bone dry!
had a feel around all plastics up under and all dry :confused:
it must be coming from up in there somewhere:shrug:
either a small leak from the edge of the windscreen of top of the bulkhead.
not had to much time to investigate.......might be worth others checking the panel under the glovebox :shrug:
I have exactly the same issue. I've found the pollen filter and grommits to be fine. Any ideas where else I could be coming from? :confused:
