Cupra Gsy
200
Hi i have just been searching threw what turbos people use and was thinking of KO4 myself but its seems like a lot of hassle and then there is ko3s but i wanna go a bit more than that so can anyone say which ones they use of have seen which work better than ko3s
Bobby
Dont worry Jay all info helps
What sort of BHP we looking at with hybrid and which companies do this? And do i have to supply the ko3s first.
yeah its a straight bolt on and you will be looking at 250bhp plus, turbo dynamics do them and i think jbs. Its cheaper if you do supply them with a turbo it doesnt matter if it knackered ether, but if not you can buy it off them, think my was £1100 but that was a year ago or more, when they were less known. i bought a complete turbo
you can take a ko3 or ko3s they just keep the exhaust part and put on a ko4 housing with turbine blades from rs6 turbo. manner on here got 276hp with hybrid turbo you can use lcr tip here you can see the hybrid turbo
was made by CR Turbos. cost i think £590, and thats witth all the delivery charges as they pick up and drop off the turbo from your house,
you need 225 injectors and maf 4bar fuel pressure reg! and a new map. and to get the best out of it fmic tip full exhaust system and the rest
Could you still run on revo stg2 (k03s) or do you need a new custom map when fitting k03(s) hybrid to get the full out of the turbo???
Prebs
I have a Uprated Jbs Tubular manifold & K03 Uprated turbo with Rs6 Internals for sale mate if your interested its only done 5k.
The Manifold was £460.00
& the Turbo was £900.00
Could do you a good deal on both or just the turbo.
