How accurate is your trip computer's MPG?
ibiza lad
I've got a 08 plate Ibiza FR TDI. I've now done nearly 7000 miles in mine. The one thing I’ve noticed is how inaccurate the trip computer’s MPG reading is. I've average about 46mpg over the 7000 miles. That is measuring all of the fuel I have put in the car. [Yes I know I am sad, I keep a log book of fuel]. The overall average [2] reads about 57mpg. So that is way off.
The trip average [1] is also way off. As an experiment I did a 200 mile motorway trip with the cruise control set to about 55 mph, in sixth gear. So I was doing about 1700rpm give or take. The trip computer suggested a magical 75mpg, in reality I’d used about 15 litres of fuel which works out at about 60mpg.
So both are way off! I was just wondering is this typical of the VAG trip computer or should I raise this with the dealer at the next service? Or does the way you drive affect the accuracy?
st10587
i only brake for cake!!!!
Oct 4, 2007
3,669
Hindhead
i had mine read 80 odd mpg on one trip :blink:
where abouts in guildford you from i should keep a eye out for ya!:)
ciano125
61
Barnsley, South Yorkshire
Yep, they're miles out. I've done 10k miles in my 07 reg FR TDi and overall it is averaging low 40s, the trip (2) says high 50's. It even said 90mpg on the way into work last week. I cant get more than about 520 miles to a tankful (about 50 litres).
fatcatman
52
I hate these threads because everyone gets much better mpg than me!
Before re-map I got 56-7mpg at best on the trip, 42-44mpg real life and after re-map I get 45mpg at best on the trip and 39-40 mpg in real life.
Car is a 'facelift' FR Tdi
nealo
88
Guisborough
I've calculated my mileage over the last 4 tanks' worth of shell v-power diesel and the trip computer is only +0.2% out! :)
2 Many Ibiza's
My 2007 Petrol FR over reads. The gauge says i average 40mpg but im actually only getting 36mpg:blink:
TazB
Xbox Gamer Tag = TazCupra
Mar 23, 2007
666
Glasgow
to every 1... whats your exact method of calculating the real mpg? i've never done it.
markthommo_84
246
England
I worked mine out a few tanks ago. I always reset the [2] bit when i fill up, i did 440 miles before refilling again, and it took 40 litres to fill, which i work out to be 49.94 mpg, the trip computer said 50.0
I can live with that! i have read most of the diesels over estimate. i think it depends on how you drive, how far, etc. obviously the longer journeys get a more accurate average - more data to calculate.
TazB :
calculating MPG - miles divided by litres X by 4.54.
440 miles to 40 litres.... 440/40, times by 4.54 = 49.94
or, use: http://www.torquecars.com/tools/uk-mpg-calculator.php
it remembers your last 4 entries, gives an average mpg over your last 4 tanks, and gives you a cost per mile. mine's 9 pence. fuel cost only obviously.
Dec 5, 2007
882
Kilmarnock, Ayrshire
I've only once done over 400miles to a tank and that was almost constant motorway driving going down south - then again i don't fill it up often. I'm going to now though!
TazB
Mar 23, 2007
666
Glasgow
ach i only put 20 quid in at a time unless i know im gonna go far.
so when you fill to the brim are you venting aswell? cos when venting it depends on how much patience i've got, how much i can squeeze into the tank
luna fr
61
Macclesfield
It doesn't matter if you vent or not as long as you fill up the same way both times, I fill up every two weeks and I have checked a couple of times the MPG vs Computer and it seems to over read by about 2MPG. Its a pre-facelift fr Tdi.
