Knackerd key fobs - a straight answer! SEAT Techie anyone...
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
.... by swapping over the central convenience module it's just possible some extra functions could be activated?
how do you think we found out the cruise control codes, took 2 cars in stock side by side with same options bar cruise - one software code difference later and hard wiring - voila :)
may just be coding of the original unit if it's same part number but must confess there is quite a few options CCunit wise so would imagine there will be more to it
UncleFester
Grumpier by the day!
Apr 30, 2006
4,764
Milton Keynes
www.facebook.com
In which case is it worth compiling a model / sub model matrix of all the modules listed under vagcom - included in that being what options you have working on your car?
Dec 31, 2007
1,479
Reading
that would be a genius idea but a big document.
Do you mean like a family tree style? Would bea great idea as it *should* show a lot of things you need to know to open loads of options.
UncleFester
Apr 30, 2006
4,764
Milton Keynes
www.facebook.com
It's actually not that much work .... we'd just need a handful of people with Leon / Ibiza / Altea etc etc and we'd be away and laughing.
Why isnt there a Smiley that shows somthing going completely over your head - 'Whoosh' etc ;)
Each 'module' in the logging and control software that we use to talk to our cars computery bits has a module number / code. By comparing code numbers with what options are available, such as electric folding mirrors - you can see which control module is required to get a particular option working. Or you can read the individual code changes that need adding to other modules to allow that functionality.
I hope that makes a little more sense?
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
most of them from part number alone i could compile the basic options
elec mirrors/windows/front/back etc
its mainly a case of matching 2 numbered units with different soft coding and knowing what the difference means i guess
