The cupra R interior is the same just with different material down the centre and logos.
Stripped with fixed buckets and harnesses ftw!
Cheers for the replies guys, I was thinking maybe interior from a porsche to go with them same theme anyone know any that will fit straight in?
James
At the end of the day you can make anything work as long as you put you mind to it.
there too wide, also the recaro s3 seats are too wide, best option i think are the tt front seats with standard rears trimed to match, or just retrim the standard interior
How much wider are the than standard? would the actual seat catch on the rest of the door cards, or is it just the runners that are too wide? Could they be fitted with modification, or is it literally impossible?
S3 Recaros are too wide?! - You've just messed up my plans with that comment!
I saw a Lupo gti using them at the last Edition38! If they fit a Lupo, then surely will be ok in the Cupra?
