installing super chip
GTV
Veggie powered TDi's
Feb 16, 2008
479
Cambridgeshire
to be honest if you have to ask, I would say get somebody to do it for you, the last thing you want is is one screwed ecu and chip.
GTV
Feb 16, 2008
479
Cambridgeshire
i just thougt that the corner with the hole in went facing the bottom of the ecu
no it is not as streight forward as that, first of all, you must fine the right ic to remove, once you have you have to remove it by desoldered it (taking care if its double sided print) or if you are luck it might be in a socket (my guess would be no it would be soldered in) once you have removed it (noting which way round it went) its just a case of refitted the new one.
I would say the fact you have to ask all of these questions you are not up to the job, not being funny but I have seen it so many times at work where people have had a go because "how hard could it be!" and realy F$%ked things up.
m0rk
sarcasm comes free
27,785
33
Clanfield, UK
***off topic*** nice to see somebody spelling EEprom right for once :) all of my shop staff put just one E.
hah, damn my 10yrs in Electronics & like 5 in education before that :)
But I bet that placing said EEprom & PCB on the metal in the pic below will have done wonders for it.
can you spell ESD?
GTV
Feb 16, 2008
479
Cambridgeshire
yeah but to be honest I find EEproms not to bad for es damage, its mirco's that I have a real problem with, if you could see my draw of 24c16's at work you would have a fit ;)
