rikwheeler
131
Lincoln
www.rikwheeler.com
I've searched on the forum and a lot of people go for 15mm back and 10mm front.
Got some 10mm for the front but wondered if anyone has fitted 20mm on the back?
Has someone got a pic of them on?
I would like to see pics of this as well.
I fitted 20mm rear spacers to my old Ibiza cupra but got rubbing, looked good tho and transformed the cars handling.
Is it the same kind of deal with the much bigger Leon???
I heard 20mm rub on the inner arches which is why I went for 15mm's. Mine is very close when fully loaded, wouldn't like to try the extra 5mm tbh!!
Where the hell do you get the extended bolts from? Mine has 5mm spacers on and I had to special order 33mm long bolts!
infact they are next to the blue box on the top shelf of my garage in the sig....
is there alot of difference in fitting the spacers! if you have 10m front and 15m at the back do you need longer bolts on all
If there the type of spacers that bolt to the car then the wheels bolt to the spacer then you don't need longer bolts.
If there just normal spacers you need longer bolts on any spacer thicker than 5mm
