perks
87
Hi all, I'm trying to wire an amp to power a sub in the boot and I can't find anywhere in the bulkhead to feed a power cable without removing the dash.
Am I being daft?
And also where would you reccomend I trail the cable i.e. route of least resistance.
Oh and pictures would be biblically helpful!
Many thanks
Carl.
Hi Flapper.
If you're reffering to the one tucked up in the top corner nearest the centre console then I've tried buddy but there are too many cables being fed through to squeeze another width ways.
And Halfrauds want £70 effin quid (before the atttacks come, I thought they'd be easy and cheap).
it is easy bud pull carpet down passenger side and then look in engine bay and u will see a grommet bud:)
wired my ibiza (which i rekon should be the same) a few weeks back, theres a hole just under the passenger glove box or airbag depending on what model you have, its plugged with a rubber bung jus push it out with a screw driver but be careful i pushed mine out and i never saw it again lol
run it under the car and up through the boot??
Thought about it until I saw the state of my cold air intake. I'd need reinforced cabling with a million earth points. Sure gravel and general road crap would leave you with a big floppy live flying around all over the place?
google vechicle wiring products dot eu( it wont let me post the url)!!:think:I've used this crowd before when rebuilding the landrover, or this there a way to feed it through with the clutch cable or throttle cable?? could you feed a cable to the fuse box??
Hi guy's i work at halfords in canterbury its £39.99 to fit a sub/amp combo but heres alittle help lift the right hand side scuttle panel up and u should see the pollen filter unclip this and the casing unscrews and u shall see the big round rubber gromit remove this and cut a cross in it then push ur wire thru and look in the passenger foot well
(DO-NOT RUN A UNPROTECTED CABLE UNDER THE CAR !!)
Good man, I'll get on it!
Got her all wired in and all, question though the power from the battery is confusing the hell out of me. If i put the feed cable to live there is no power through it, same with neutral however if I touch the live and THEN touch the neutral the amp powers up for a second and then dies.
PLEASE HELP! 3 hours in I'm ready to put the bugger in the nearest bin!
ok so u have run the power lead from the battery and conected it onto the 12v connection of the amp hopefully u have also found a good earth in the boot and connected that to the neg -12v of the amp and run a remote wire from the headunit to the rem connection on the amp
power lead from battery to +12v amp
earth cable from chassis to neg (-12v) amp
headunit remote to REM on amp
All done minus the REM, I'm getting the signal from my rear speakers as my HU has no amp out. What is the REM?
It's a cordoba matey.
So where do I need to run this REM jobby from amd do you think that's what's killing the power?
Yeah it's a sony but with no sub out whatsoever so I now think maybe the amp goes into standy if not connected to the sub?
I'm buying some cable tonight the so watch this space!
hum u should have a blue/white striped wire coming outta the block at the rear of the head unit ur need a headunit wiv pre-out's to run the signal down the RCA wires to the amp
Sony what headunit? What's the model number?
In the back, your remote wire should be orange and blue, blue or blue and white. (Normally blue)
you'll have to cut and strip the current REM, and use a connector to connect them.
"Blue" wire from head unit into one side of connector.
Other end of "Blue" wire you cut, and the new amp REM wire into the other side.
All stripped and twisted, you may want to strip the head unit side single wire further back, so you can fold the wires back on themselves and twist to make it thicker. And twist the other 2 together to make it thicker, making it easier for the connector to grip onto them (use pliers and tape)
If you need any more help, don't hesitate to post back here, if I don't reply, pm :)
:givein:
Cool, and thanks, thing is though I have connected the blue cable to the REM input on the amp and still nowt. :banghead2
I've replaced each of the cables with very cool looking zero oxygen jobbies from Maplin,
I'm thinking maybe the amp's cooked, but it worked perfectly when removed and has been looked after and properly dry stored since. :givein:
