splatrat
123
stoke on trent
i have 19 inch wheels on a 2007 tdi fr and am really confused as to what my tyre pressures should be .............can anyone help?
sorry the tyre size is 235/35/19
35psi all round would eventually wear the middles out same as 30psi all round will eventually wear out the edges of the fronts a bit but near enough ok for the rears.Best off sticking to the correct spec: which is 29psi rear and 32psi front with normal load,unless you drive all over with 4 passengers and/or a large load in the boot. Give or take the odd psi. NEVER EXCEED 32 or 33 psi EVER or buy new tyres sooner.
but with a different size tyre in my case being larger wouldnt the new tyre need more psi to fill as the older was smaller or am i just being thick?
