yes they are there, but surely they would of changed due to me changing from 17's to 19's??
35psi all round would eventually wear the middles out same as 30psi all round will eventually wear out the edges of the fronts a bit but near enough ok for the rears.Best off sticking to the correct spec: which is 29psi rear and 32psi front with normal load,unless you drive all over with 4 passengers and/or a large load in the boot. Give or take the odd psi. NEVER EXCEED 32 or 33 psi EVER or buy new tyres sooner.
Air pressure remains the same, whatever tyre size goes on.![]()
A larger tyre size only means you need to put more in to fill it = volume. psi remains the same.
Only more air needed.
