the clock that is attached to the speedo/rev counter/ entire dash unit??
if so, remove the 2 screws that you can see when you pull of the small bit of trim between the dash clocks unit and steering column, and then wiggle it out.. its an awkward bugger
cheers danny i will give that a try;);)
