the comp housing was well and truly hitting the transfer box!!![]()
That set up has such poor fitment it is not even funny...BTDT
Tight feed for oil restrictor
cant get @ the oil lines
turbocharger has no room to get @ the studs
compressor housing hits the transfer case....
and on and on....
I am surprised Bill sold you that.
That is what spawned development of our own manifold.
haha ill pop down some time and have a gander , is bill in work the weekend?
The pic of change cables in the way of the tip takes me back.
Here's how I solved it.....
Too late for you now but definitely a manifold designed to work in RHD applications be it 02M 4WD box in an Ibiza with a rear motor mount bracket or a 02M FWD box in a Leon with a side mount engine bracket.Bill was told it would fit a transverse engined quattro, we knew it would be tight but didn't expect the issues that happened.
By all accounts he has seen Jabba installs using IHI turbos that are worse....
Whats your manifold like? Got any info?
<tuffty/>
instead of hollow words, show something then.
instead of slagging others off, do something then.... other thank talking about it
There several aspects of what Pag supplied I am personally dissapointed with without doubt and have told them so.
Not having seen what you have been talking about for months, who knows what issues and deficiencies your kit of parts may have.....
If you actually have something to send which I can validate against what I know and have seen thus far on these installs, I will look at it for you to confirm... BUT you simply poking criticism at someone else's offerings when you have'nt let anyone else try yours, is simply being an ass Sam.. sorry but thats how you are coming across to me.
maybe I should post your email to me of this morning so the wider audience can see what you really say... eh?
Go right ahead Bill....maybe I should post your email to me of this morning so the wider audience can see what you really say... eh?
Now now you 2 this should be a Build thread....
take it to pm if needs be..
now thats boring
