Luke_buk
60
South Yorkshire
hello
i have a 2001 Y Reg seat leon cupra and i dont have a trip computer switch on the right hand arm.
i am thinking maybe someone in the past has changed it and put a standard one on?
should i have one or did some of the earlier cars not have trip cmputers?
please help.
must admit i didnt notice when i bought it so slightly disapointed when i realised :lol:
yeah me too. but to be honest i had one on my passat and i never really used it after the novelty wore off. and to be fair i think it might scare me seeinh how much fuel i am using
but have you seen the thread on WHAT YOU DIDNT KNOW ABout YOUEr LEON
you can set your climate control scrren to be a rev counter or spedo or load of other diag options. i just tried mine it works.
NOPE linky please!! hehe
http://www.seatcupra.net/forums/showthread.php?t=224150&page=5
this takes you oage 5 its about 2 pages back but hang on here is the codes
hanging Degree Temperature Display
Press and hold the recirculation button. Then press the temperature up ("+") button to switch between degrees Celsius & Fahrenheit on the Climate Control Temperature and Instrument Panel Outside Temperature displays.
Accessing On-Board Diagnostic codes
Press and hold the recirculation button. Then press the manual flow control up arrow. You should see a 1c. Press the temperature up ("+") or down ("-") buttons to select a code number. Then press the recirculation button again. The value should display. Press the temperature up or down button again to display another code.
NOTE: Air Flow Motor (V 71) and Potentiometer (G 113) are not installed in USA/Canada vehicles. Disregard values displayed for these components.
Code Displayed Value
1 System malfunction - displayed as a Diagnostic Trouble Code (DTC), see chart below
2 Digital value of Interior Temperature Sensor, in Headliner (G 86)
3 Digital value of Interior Temperature Sensor, in Instrument Panel (G 56)
4 Digital value of Fresh Air Intake Duct Temperature Sensor (G 89)
5 Digital value of Outside Air (Ambient) Temperature Sensor (G 17), front
6 Digital value of Outside Air (Ambient) Temperature Sensor
7 Digital value of Ambient Temperature Sensor At Fresh Air Blower (G 109)
8 Digital value of Temperature Regulator Flap Motor Potentiometer (G 92)
9 Delta value of Temperature Regulator Flap
10 Non-corrected specified value of Temperature Regulator Flap
11 Digital value of Central Flap Motor Potentiometer (G 112)
12 Specified value of Central Flap
13 Digital value of Footwell/Defroster Flap Motor Potentiometer (G 114)
14 Specified value of Footwell/Defroster Flap
15 Digital value of Air Flow Flap Motor Potentiometer (G 113)
16 Specified value of Air Flow Flap
17 Vehicle Speed (km/h)
18 Actual Air Blower voltage (Volts)
19 Specified Fresh Air Blower voltage (Volts)
20 A/C Compressor (A/C Clutch) voltage (Volts)
21 Number of low voltage occurrences, non-transient
22 Cycle condition of A/C Refrigerant High Pressure Switch (F 118)
23 Cyclings of the A/C Refrigerant High Pressure Switch (F 118)
24 Cyclings of the switches, absolute non-fluctuating
25 Analog/Digital value, Kick-Down Switch
26 Analog/Digital value, Engine Coolant Temperature (ECT) Warning Light
27 Engine Speed (RPM)
28 N/A
29 A/C Compressor speed in rpm (Equals Engine Speed x 1.28)
30 Software version
31 N/A
32 Potentiometer malfunction counter, Temperature Regulator Flap
33 Potentiometer malfunction counter, Central Flap
34 Potentiometer malfunction counter, Footwell/Defroster Flap
35 Potentiometer malfunction counter, Air Flow Map
36 Feedback value, cold end-stop, Temperature Regulator Flap Motor Potentiometer (G 92)
37 Feedback value, hot end-stop, Temperature Regulator Flap Motor Potentiometer (G 92), max. stop
38 Feedback value, cold end-stop, Central Flap Motor Potentiometer (G 112)
39 Feedback value, hot end-stop, Central Flap Motor Potentiometer (G 112)
40 Feedback value, cold end-stop, Footwell/Defroster Flap Motor Potentiometer (G114)
41 Feedback value, hot end-stop, Footwell/Defroster Flap Motor Potentiometer (G114)
42 Feedback value, cold end-stop, Air Flow Map Motor Potentiometer (G 113)
43 Feedback value, hot end-stop, Air Flow Map Motor Potentiometer (G 113)
44 Vehicle operation cycle counter
45 Calculated interior temperature (internal software, in digits)
46 Outside (ambient) temperature, filtered, for regulation (internal software)
47 Outside (ambient) temperature, unfiltered, (internal software, in deg C)
48 Outside (ambient) temperature, unfiltered, (in digits)
49 Malfunction counter for speedometer (vehicle speed) signal
50 Standing time (in minutes)
51 Engine Coolant Temperature (ECT) in deg C
52 Graphics channel 1 - A/C compressor switch-off conditions are identified by illuminated segments of the “88.8” display. See chart below.
53 Graphics channel 2 - Climate system electrical outputs are identified by illuminated segments of the “88.8” display. See chart below.
54 Control characteristics
55 Outside (ambient) temperature, in deg C or deg F depending on setting on A/C control head
56 Temperature in deg C, from Interior Temperature Sensor, in Headliner (G 86)
57 Temperature in deg C, from Interior Temperature Sensor, in Instrument Panel (G 56)
58 Temperature in deg C, from Fresh Air Intake Duct Temperature Sensor (G 89)
59 Temperature in deg C, from Outside Air (Ambient) Temperature Sensor (G 17), front
60 Temperature in deg C, from Ambient Temperature Sensor At Fresh Air Blower (G 109)
61 Software version (latest)
86 Display Check (All Segments of Climate Control display light up
