lee b
has anybody got any pictures with eibach sportlines springs fitted 50mm drop on front and 35mm drop on rear.
most pictures seem to be of 30mm-30mm drop is this normal for road cars, i don`t want to dive in and buy the wrong drop springs.
cheers lee
If you want a 50mm drop, you'll probably need coilovers. but 50mm drop will give you a minor problem at the front wheelarches. The wheelarch liner support bolt sticks out inside both front arches so may start rubbing with a 50mm drop. Solution could be removing these and cutting away the excess plastic.
i`ve noticed that you have a 35mm drop on yours with the kw`s, do you have any probs with catching etc? could you send a picture of your car.
cheers
lee
I've got minor scraping on the bolt, but that's brought on by the 10mm spacers. before the spacers everything was fine.
Here's a few pic:
