You can't leave it for a long period of time then because the sidelights stay on do they?
Coming Home lights feature should already work as standard - mine has the leaving home lights feature enabled via VAG Com which means when you unlock the car your headlights come on.
Mine doesn't have Auto Headlights, so only does this when I've left the headlights switched on when I've left the car.
You dont have auto headlights but the lights come on when you unlock the car? I tried this in VAGCOM and failed as I dont have auto lights either. What settings in VAGCOM do you change? The guide Dan did didnt seem to work on my car.
Currently well jealous ov a mates car (Mark 5 Gti) whos headlights turn on when he unlocks his car. Looks well cool with xenon headlights.
Is it possible to fit the "coming home headlight function" after buying the car?
If so has anyone done it before or knows how to do it?
Many thanks
Well the "leaving home"function is at long last working on my car too now
What you need to do in addition to adjusting Bit 5 in in Byte 1 for the Long Coding for Module 9 is adjust the time setting in module 46, channel 2 for leaving home lights. It was set to 0 as default on mine, but it has been adjusted to 40 now to be the same as the coming home setting
Cheers also to Dan![]()
i'd like to change a few settings but dont think that justifies me spending $300 on the cable, I suppose Seat will do it for a few quid.
I think if you went into a Seat service department, and told them you'd like the Leaving Home feature enabled on your car, you just get a very blank look unfortunately....![]()
And charge you an arm an a leg if they actually can do it. Why not go to a meet in London and have the likes of Dan do it for you?
Yea, I would do.... depends when they are though (I'll look now).... don't get so much free time, kids, work...... ps3
Plus, I don't know Dan so don't want to take the P!![]()
