Coming home lights
iandjm
272
Isle of Wight
Hey,
Does anyone know the sequence to set up coming home lights on mt SC sport? I have the convienience pack on the car so it should be included. I have looked in the manual and a sequence of turning switches, opening door and turning ingition off is mentioned, but this does not work. I would imagine once activated it should work every time? As long as the headlight switch is left on?
Ian
mick-fr
Mégane F1 R26..
Dec 1, 2009
2,406
At a Shell garage..
Hey! First post!
Duno if its the same, but in the corsa I had before the Ibiza you turned off the car, removed key, opened the door, flashed the full beam and that was it.
Duno if that will help, sorry! :)
iandjm
272
Isle of Wight
Hi,
Mines the sport, but when you add on the convienience pack it also adds the coming home lights :) We sure need them in the winter here :)
Nov 6, 2007
893
Newark
what you need to do is
turn the car off
Turn the lights off
open the door
then pull the the leaver as tho you are flashing someone and the lights will come on
lock the doors and then they will go off after while
in the manual it does say push but you have got to pull
topleya
MK5 Ibiza FR Black 1.2TSI
Nov 23, 2007
78
Just accidently found out I have these on my Good Stuff, wasn't even aware I had these at all, so it sort of freaked me out at first.
davidmack
127
Glasgow
what does the convienience pack have? I tried the coming home lights and it worked, but didnt know I had the pack....
